Sep 28th, 2011, 9:06 pm
Hyper throttle is pretty hyper
Ok gang gots a question for ya..I just got my hyper and it has a bunch of go fast goodness done to her. DP Cams, full 2-1 Termis, DP ecu, open airbox, and a lightened flywheel. The throttle on this beast is Damn near dangerous on how abrupt it comes on and goes off. What I am wondering is, could the flywheel be the culprit? Could the ecu be reflashed?
Thanks guys for any help.
Sent from my PC36100 using Motorcycle App
Have
Silver 2007 S2R1000(my baby)
Charcoal Gray 1999 900 Monster
Black 2005 S2R800
Titanium 2007 S4Rt
Had
Black 2004 999S (Traded for Hyper)
Yellow 2004 749s (traded in for S2R1000)
Yellow 1997 748s (sold)
Red 2008 Hypermotard 1100s (sold)
If ya want Cars Suck stickers, PM me with an address and I will send some.
I really have no idea what I'm doing.
Sep 28th, 2011, 9:31 pm
Pretty much all of the above.
Generally anything you do to increase power is going to detract from ridability. Why did you do all that, are you going racing?
Rick Yamane
Motion Pro
Sep 28th, 2011, 9:33 pm
Pretty sure he picked it up already modified by the previous owner...
'11 Hypermotard 1100 Evo
'03 DRZ400E, converted to SM
Sep 28th, 2011, 10:00 pm
The "throw" can be fixed by paying attention to the throttle tube's cam on your current piece; assess the shapeliness. Think "progressive cam profiling". You may modify a tad by dremel... conversely there are plenty of companies who will take Your monies. Motion Pro has a kit. G2 Ergonomics...
I personally chose a Yamaha R6 tube to attain the wider profile under half-throttle, yet a shorter throw than oem. Basically, once I reach half throttle and beyond, the throw is more abupt, as it should be. Now I may savor the twist in early gear, and twist heartily after half throttle.
'09 HYM1100S Nero
Sep 29th, 2011, 1:08 am
My S has those mods plus velocity stacks. I don't see the throttle being super sensitive. It can be nuts if I so desire, but that's controlled by the right wrist, clutch action and gear selection. I'm not sure what your question is?
Sep 29th, 2011, 3:36 am
Reset the throttle position sensor, let the dealer adjust your bike´s CO and see how you go from there.
Sep 29th, 2011, 3:43 am
I had the same issue. Just adjusted the fuel trim(CO) and synched the throttle bodies and now its perfect.
Oct 1st, 2011, 8:31 am
throttle is definately hypeer
i am not a fan of the throttle response at all on my hyper!! a while back i was gonna look into a fix or something to at least make it not so jerky at low neighborhood type speeds. any one with a success story on that..
Oct 1st, 2011, 8:54 am
Read the two posts above yours.
Oct 1st, 2011, 5:33 pm
Maybe it's your hand.  I got a substantially upgraded piece from an evil M.D. in Belgium; Bolted right up.
'09 HYM1100S Nero
