Tires for the hypermotard. - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com
Old Sep 27th, 2011, 6:00 am   #1 (permalink)
Hi, I understand that we run our tires front 120/70 and rear 180/55. What are the tire pressure for the tires for road and track? And have anyone run larger tires on their hypermotard, tire pressure for them also? Thanks!
AlmightyAdrian is offline   Reply With Quote
Old Sep 27th, 2011, 6:57 am   #2 (permalink)
Drinky's Avatar
Images: 3
Depends on the tire and your preference. I run pilot powers(regular) with 2,4 bar front and 2,7 in the rear. Bigger tires like a 190/50 or 190/55 will give you a smaller contact patch and a slower turn in. I've had them on my bike and they were just awful tbh.
Old Sep 27th, 2011, 8:14 am   #3 (permalink)
nickd64's Avatar
Pilot power pure also - 33 front & 36 rear. That is for road.
Nick - 2008 Hypermotard S
nickd64 is offline   Reply With Quote
Old Sep 27th, 2011, 9:40 am   #4 (permalink)
Thanks alot guys for the response. I'm running on pilot power pure as well, great tyres!
Old Sep 27th, 2011, 9:44 am   #5 (permalink)
08hyper's Avatar
Street tires at the track, start at 29-30 psi (cold) F/R, go from there. Aloha Alex
Old Sep 28th, 2011, 10:39 am   #6 (permalink)
vroooom's Avatar
so should the tires be higher or lower (pressure) on the street compare to the track?
Old Sep 28th, 2011, 11:22 am   #7 (permalink)
el tardo's Avatar
best bet is look up manufactures site for info
on dunlops Q2 for track they say 32f32r cold--street 34f36r
ntecs(best dot race tire made) 31f 21r cold
every tire is different.street ,like commuting you want higher to make the tire last longer but not to high.
2010 black 796
dont make me badge you!!
Old Sep 29th, 2011, 8:01 am   #8 (permalink)
puchika's Avatar
Is the front usually a bit lower to better soak up the bumps?
2009 Monster 696
2011 Hypermotard 1100 EVO
puchika is offline   Reply With Quote
Old Sep 29th, 2011, 8:20 am   #9 (permalink)
Good question from Puchika. I was wondering on that too.
Old Oct 10th, 2011, 9:55 am   #10 (permalink)
protokultur's Avatar
Exact same for me and it has made a wonderful difference in the city. Was running battlax 016's on 32-ish psi before. Front and rear wear pattern looked as if pressure was OK but tire life was only 2500-3000 miles.
protokultur is offline   Reply With Quote
Wtb tires hypermotard 2010 evo Jwduhon HyperMotard 30 Sep 13th, 2011 7:32 pm
A REAL biker - Hypermotard with spiked tires amullo HyperMotard 12 Apr 7th, 2011 12:27 am
Tires paul0812 Apparel and Accessory Chat 2 Aug 10th, 2010 7:53 pm
NEW Hypermotard Performance TIRES!! 08hyper HyperMotard 18 Sep 9th, 2009 3:45 pm
Hypermotard tires Tom HyperMotard 14 Aug 5th, 2009 6:55 pm
