Chain for the hyper - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com
Old Sep 26th, 2011, 3:19 pm   #1 (permalink)
Drinky's Avatar
Images: 3
Chain for the hyper
So, my chain is at its end after serving the bike for 12.000 miles, and I need a new one, together with new sprockets(they're not worn, but I might as well replace those too since they will be in a few thousand miles). I was looking at getting AFAM sprockets, but don't know which yet( will probably keep same ratio as the power's good as is). What chain do you guys run on it? I want something that lasts a bit longer than just 12k miles, so O-ring will be out of the question, but what kind of X or Z ring chain should I get?
Old Sep 26th, 2011, 5:44 pm   #2 (permalink)
NikMusolino's Avatar
EK MVXZ Series... tensile strength is 9,300 lbs. for 525 pitch. They run for $150 USD.
'09 HYM1100S Nero
Old Sep 26th, 2011, 8:05 pm   #3 (permalink)
I had a DID ERV2 on a previous bike and liked it.
I'll probably try the ERV3 on the Hyper when the time comes.
velocita is offline   Reply With Quote
Old Sep 27th, 2011, 3:08 am   #4 (permalink)
vroooom's Avatar
Originally Posted by Drinky View Post
I want something that lasts a bit longer than just 12k miles, so O-ring will be out of the question....
o-ring chains don't last longer than 12k miles? i thought they are better?
Old Sep 27th, 2011, 5:26 am   #5 (permalink)
Drinky's Avatar
Images: 3
Well, I've heard the x-ring seals are better than o-rings. And this is my 2nd set of o-rings that has died within 12k miles
Old Sep 27th, 2011, 11:06 am   #6 (permalink)
08hyper's Avatar
I use the D.I.D 520 ZVM-X chain, (X ring) the only 520 chain that I know of that is rated to 1200cc. (Superstrong)
I also use a Supersprox rear steel/aluminum sprocket, with the 520 chain, & have about 10,000 mi on it, so far so good.
I hear that a "O" ring chain seals better but a "X" ring chain has less friction. Aloha Alex
Old Sep 27th, 2011, 1:18 pm   #7 (permalink)
what is the criteria you guys are using to decide if its time to replace?
i have 12000 miles on mine and it seems to be fine...
ClearyCoachworks is offline   Reply With Quote
Old Sep 27th, 2011, 3:06 pm   #8 (permalink)
Drinky's Avatar
Images: 3
when there are hard chunks or links in the chain, or you can pull the chain 3-4mm from the rear sprocket, or you feel a weird ticking sensation in your right footpeg which goes faster and slower as you accelerate and decelerate.
Old Sep 27th, 2011, 3:59 pm   #9 (permalink)
protokultur's Avatar
Do the whole shebang!
AEM magnesium carrier
42t 520 ergal rear sprocket
AEM cush drives / Ti bolts
Superlite 14t 520 front sprocket
DID 520 ERV3 chain
protokultur is offline   Reply With Quote
Old Sep 27th, 2011, 4:47 pm   #10 (permalink)
Drinky's Avatar
Images: 3
DID 520 ERV3 chain
If I had the money, I would, but I see no reason to change my stock configuration.
So I came across the DID 525VM2 which seems to be listed for my bike, is this the correct one?
Which Chain Guard Case Saver fits the Hyper EVO. What engine does the EVO have? krisnet55 HyperMotard 4 May 19th, 2011 6:44 pm
Hyper passenger pegs, front fairing and rear chain guard asado Parts and Accessories 0 Apr 20th, 2010 2:18 pm
Hyper passenger pegs, front mud guard and rear chain guard asado Parts and Accessories 0 Mar 4th, 2010 10:22 am
WTB, Hyper chain guard Kinkykelly Parts and Accessories 5 Dec 18th, 2009 9:54 am
Tips - Hyper Chain Adjustment and Clutch Cooling! GNGYoung HyperMotard 3 Nov 16th, 2008 10:27 pm
