Sep 22nd, 2011, 12:10 am
DP handguards o 796
Just received DP handguards and mirrors. Any one installed these?
Seems like they fit better on the 1100 since the fluid reservoirs are mounted different. I got the mirrors to fit despite the crappy black and white pictures in the installation guide, basically useless since I could not make out anything from them.
The handguards came with color photos but the quality is rubbish. I can fit them on the bike but the part about how to add the optional extension on the guard I'm a bit usure of...
Any suggestions or proper photos?
Thanks and kind regards!
Black HM 796 -2011
Sep 22nd, 2011, 5:57 am
I installed my DP mirrors and handguards about 3 weeks ago. Mirrors went on fine, but the handguards were a pain in the ass.
I had to cut just about everything included as mounting hardware and even my handlebar since it leaves an openening in them if you don't cut it. In the end though, I'm pleased with the results, but I can't believe how crappy the instructions and fitting were.
Have fun!
Sep 22nd, 2011, 10:33 pm
Check out this link Project Ducati Hypermotard Part III: Protection
Sep 26th, 2011, 10:28 pm
You can some pics of my DP handguards at the following thread;
Anyone tried a Puig windscreen?
btw, i had them installed at the local Duc distributor.
Sep 27th, 2011, 3:38 am
so i went and checked mine and low and behold it's now loose. i tried tightening the bolt/screw but they are tight. i guess it's that tab inside that's the culprit? should i just JBweld this thing?
Sep 29th, 2011, 4:28 am
Originally Posted by dimitrinassis001
dimitrinassis001:
That is a 1100 by the looks of it, I believe they do fit better because of the different fluid reservoirs. On a 796 it does not seem to fit well. I cant even use the aluminum clamp for the hand guard since it clashes in to other parts. Am away at the moment so cant post any photos...
Black HM 796 -2011
Sep 29th, 2011, 4:39 am
Originally Posted by TheTaj
TheTaj: Hows KL? Was down there few weeks ago.
Did they drop down the levers to make it work? I fitted one before I had to leave urgently for work and did not have to much time to play around. Did they use the original hand guard clamp or the aluminum clamp that came with the kit for hand guards?
Cant really see the details from your link but thanks anyway
Kind regards
Black HM 796 -2011
Sep 29th, 2011, 10:52 pm
I don't know if id do that cuz that shit doesn't come off easy. My hand guard was loose when I replaced it after i dropped my bike on myself and I broke the mirror. I loaded it with threadlock and let it set and its fine now. At least that stuff aint hard to remove if you ever have to.
Sep 30th, 2011, 5:40 am
dimitri, where did you apply the threadlock? is it where the hand guards meet the handlebar?
Oct 4th, 2011, 3:08 am
Kind regards
Hi nbg,
will take more pics of my set up and post here,
btw, KL is the usual, humid and wet...
