Sep 18th, 2011, 8:48 pm
Handgard bar end fix macgyver style
After waiting for nearly a month to get parts replaced from the dealer for My new HYM796, and although once they got them ordered it was quick . . . . I got impatient and developed a fix that has been working rather well.
The second photo is to show the relationship of the roll pin to the bar end notch, there is one on each side. The piece is not attached an is pulled away to illustrate this, When attached, it is nearly flush to the grip.
Sep 19th, 2011, 3:16 am
What holds the roll pins in place?
Maybe I'm missing something (I'm not too bright) but it would seem that the roll pins could....ummmm.....roll in the mount and allow the handguard to rotate anyway.
Dave
My DOC Welcome Kit
Dave Yeski
CCS Southwest Expert #99
(apparently retired....  )
2008 Hypermotard S Black!!!!
2006 Yamaha YZ450F Supermoto
Sep 19th, 2011, 6:42 am
The roll pins are pressed at .400 - .425 into the plastic. That part of the hand guard is a nylon66, or a 40% GFN (glass filled nylon), high impact/shear strength.
So far it been working perfectly.
What were your thoughts?
Sep 19th, 2011, 7:05 am
I don't believe that part
Sep 19th, 2011, 7:25 am
I have no thoughts......
It looks like it would work well, good job.
Dave
My DOC Welcome Kit
Dave Yeski
Sep 19th, 2011, 10:34 am
Dave
I do..............but to his defence he is FAST!
Aloha Alex
Sep 19th, 2011, 5:53 pm
how do you put the pin in? drill a hole? do you use glue at all?
Shorty toetip on a 2010 HM 796 Ducati Red
Stock exhaust/pipe --> LV decat($261)+stock can
Stock air box/filter --> KN filter($64)+Lid removed
Stock rear fender/plate holder --> evotech tail tidy (ebay $104)
Stock mirror/handguard
Stock ecu --> PCV+opt($350)
Stock map --> Dyno map ($350)
Stock handle bar
Stock seat --> Custom lowered (DIY) + upholstery touch up($80)
Stock fork --> Andreani (Group) Fork ($1300)
Stock shock
Stock fairing --> DIY black-tinted windscreen($25) + chinese fake carbon rear hugger ($160) + DIY hugger extension ($16) NEW
Stock sprocket --> stock front+44T supersprox rear($150)
Stock levers --> MC short levers (ebay $58)
Sep 19th, 2011, 6:18 pm
No glue. It is a press fit. The pin is made from a grade of spring steel. If you notice the gap or split running down the length of
the pin, that is the "tolerance" built into the pins functionality which allows it to close in on itself. Since it is spring steel, it will
always be under a load within the cavity in which it is pressed into. That is why it stays in place.
You start with a hole that is .007 -.010 smaller than that of the outside diameter, (OD) of the pin. At least for this pin diameter.
You could put a touch of JB weld down in there, however there is not enough surface area where the pin is to be effective.
Sep 20th, 2011, 1:19 am
Aloha Alex
That's right.....Fast and Stupid....
Ironically, I like my women the exact same way.....
Dave
My DOC Welcome Kit
Dave Yeski
Sep 20th, 2011, 5:24 am
may i ask.... what's the issue with the hand guard? are we all eventually going to have this break on us?
