Getting a hyper ready for a track day? - Ducati.ms - The Ultimate Ducati Forum
Old Sep 16th, 2011, 12:21 pm   #1 (permalink)
Wiscy's Avatar
Hey guys im thinking about entering a couple track days. I would be in the beginner class, never been on a track before with a bike. What do you guys do to your hypers to get them ready as far as like with your headlight and tail lights, blinkers ext. to pass tech inspection?. Would i need to get number plates? What should i expect at a track day? This is all new to me so any tips or tricks would be appreciated.
Thanks in advance
Experience is something you don't get until just after you need it.
2008 Ducati Hypermotard 1100S.
FULL Termignoni carbon race exhaust with DP ECU and high-flow air filter
Ducati Peformance steering damper kit
Speedymoto open clutch cover and anodized pressure plate
short license plate mount kit, carbon tank pad
Wiscy is offline   Reply With Quote
Old Sep 16th, 2011, 12:29 pm   #2 (permalink)
froggert's Avatar
depends on the track day organizer. around here, all you usually have to do for the beginner group is tape up your mirrors, lights and reflectors. if your bike is in solid enough shape to ride on the street, it should pass tech.
1098s, m620, m750
froggert is offline   Reply With Quote
Old Sep 16th, 2011, 12:59 pm   #3 (permalink)
Decreasing Dave's Avatar
Images: 14
Drain the coolant.....
Dave
My DOC Welcome Kit
Dave Yeski
CCS Southwest Expert #99
(apparently retired....)
2008 Hypermotard S Black!!!!
2006 Yamaha YZ450F Supermoto
Old Sep 16th, 2011, 1:04 pm   #4 (permalink)
johnchypermotard's Avatar
bring LOTS of duct tape ... just ask alex
Old Sep 16th, 2011, 1:05 pm   #5 (permalink)
and don't be on the outside of marco on turn 5
Old Sep 16th, 2011, 1:17 pm   #6 (permalink)
Drinky's Avatar
Images: 3
Raise up the rear, and if the track is sufficiently smooth just stiffen up the suspension a bit(assuming you don't have stock springs and oil), tape up mirrors and other glass parts(don't tape up your headlight, it will melt).
Old Sep 16th, 2011, 3:03 pm   #7 (permalink)
But
Dave
I almost said don't forget to fill it back up with water wetter and water ( good one)
Bourkeco is online now   Reply With Quote
Old Sep 16th, 2011, 4:05 pm   #8 (permalink)
Ben710's Avatar
Just to fuck around at the track, remove the lights and the street stuff like handguards and mirrors as they´re very expensive to replace.
You should have a proper set of tyres. If you can afford them, get some sticky rubber of your fav manufacturer.
Once you get up to speed you need to get the stock footpegs and foot controls out of the way. You´ll destroy them dragging them.
But for your first track day, go there and have fun! Make sure the bike is in proper working order. You´ll see where problems will arise while you´re at it.
Check the trackday organiser´s rules for participation. Some require you to safety wire the fluid related bolts.
Old Sep 16th, 2011, 5:25 pm   #9 (permalink)
Axle sliders, and the DP race handguards just in case.
Ted
r60slash5 is offline   Reply With Quote
Old Sep 16th, 2011, 5:59 pm   #10 (permalink)
freezer16801's Avatar
remove non-essentials like ben said. I also remove my passenger footpegs. I remove my lights all together to include my headlight. The less you have to replace if you crash the better.
It doesn't hurt to change the oil and filter before you go if you have a few thousand on. I agree with others about tires. Use something good with lotso of life. All you learn riding on worn tires is how to ride on worn tires.
08 Ducati HM
03 Yamaha R6 track bike
02 Suzuki TL1000-R RIP baby
Getting the GT ready for tech @ track redrover Sport Classic 19 Sep 24th, 2010 2:41 pm
Anybody else ready to buy a Hyper NOW... Antigrav HyperMotard 14 Sep 27th, 2008 12:51 am
Pic's track ready Hypermotard Shift-Tech HyperMotard 22 Aug 7th, 2007 10:26 pm
getting the ST ready for the track butch Sport Touring 6 May 21st, 2007 9:32 am
track ready bobert421 Superbikes 11 Oct 30th, 2006 1:09 pm
