Sep 15th, 2011, 9:46 am
Speed Bleeders
Just wondering if you guys have replaced the OEM Brake Caliper bleeder niple with the a Speed Bleeder Valve System on your Hypermotard...Happy with the results...???
What model Speed Bleeder should I use if I go that route???
2008 Hyper 1100
Cheers
Pura Vida!
Philip
Sep 15th, 2011, 2:24 pm
...there is no such thing as a 1998 Hypermotard.
And Spiegler is the way to go.
'09 HYM1100S Nero
Sep 15th, 2011, 3:29 pm
Banned
Mattias makes good stuff for sure.
Sep 15th, 2011, 4:16 pm
Ha...stuck in the 90's I guess. Its a 2008.
I will check out Spiegler...thanks!
Pura Vida!
Philip
Sep 15th, 2011, 6:18 pm
MotoWheels: Spiegler Speed Bleeder
'09 HYM1100S Nero
Sep 15th, 2011, 6:27 pm
Not sure I see the advantage over a check valve.
You are still going to have to attach tubing to the nipple when you bleed the lines, so why not just use a $4 CV.
Sep 15th, 2011, 6:57 pm
http://www.youtube.com/v/QVjPVhoPHow...dded&version=3
'09 HYM1100S Nero
Sep 15th, 2011, 8:06 pm
I have done bleeding the old fashioned way, tried Speedbleeders, MityVacs, EZE Bleeder, etc. IMHE, if you want to make bleeding almost effortless to do, especially alone, the Motive Brembo Powerbleeder can't be beat:
It's not cheap ($75) but I can bleed my clutch and front and rear brakes in 15 minutes, no mess, alone. You put fresh fluid in the power bleeder, screw the billet brembo attachment to the reservoir you are flushing (in place of OEM reservoir cap), pump pressurize the power bleeder, open the bleed screw, wait until the fluid runs out clear, tighten bleeder, done. No pumping or zip tying levers, opening and closing bleeders, watching and refilling reservoir, etc. It is basically a poor man's version of the professional power bleeder shops use. And it's great for the track when you need to bleed quickly.
[no affiliation with company just terribly impressed with product]
Sep 17th, 2011, 12:20 am
Amazon.com: Motive Products Brembo Front/Rear and Clutch Power Bleeder MP-0160: Automotive
Yes, but the "field-worthy" Spiegler + bag set-up is fitting for the guy who doesn't have the garage away from the garage... FWIW That bag and line fits in the LH fairing compartment.
'09 HYM1100S Nero
Sep 17th, 2011, 1:33 pm
not to mention that you can get basically any attachment that you want so you can flush the fluid on your 76 plymouth volare or whatever other cage you own. I've owned one for years, but recently the pump took a shit.
08 Ducati HM
03 Yamaha R6 track bike
02 Suzuki TL1000-R RIP baby
