SP wouldn't start, then would, then wouldn't... It was the key, then it wasn't. - Ducati.ms - The Ultimate Ducati Forum
Old Sep 15th, 2011, 12:33 am   #1 (permalink)
Maximo's Avatar
Left work and it took 3 tries on the starter button. Lights, power, no starter. First time it ever that it hasn't started on the first turn.
Got gas 10 minutes later and took 5 tries to start. hmmm.
Left a restaurant an hour later, took 8 tries, *hit, what's wrong?
Got home (fortunately) and then wouldn't start at all; same lights, checks, hum, no starter as if it was immobilized.
Spent 2 hours checking kickstand sensor, battery, wiring/ground, etc. Finally tried my other key and it fired up, whew. What's weird is that later I tried it again with original key (with other key separated in house) and it started right up with no issues?
I searched and found in another thread that the MTS key fobs get interference from iPhones, which I have, but it didn't seem to be related here. Anyone else experience this? Can your key lose it's code (gradually???) and then reset automatically once the bike gets it from another source?
Sent from my Motorcycle iPad app
Maximo is offline   Reply With Quote
Old Sep 15th, 2011, 4:31 am   #2 (permalink)
Battery voltage?
Shorty toetip on a 2010 HM 796 Ducati Red
Stock exhaust/pipe --> LV decat($261)+stock can
Stock air box/filter --> KN filter($64)+Lid removed
Stock rear fender/plate holder --> evotech tail tidy (ebay $104)
Stock mirror/handguard
Stock ecu --> PCV+opt($350)
Stock map --> Dyno map ($350)
Stock handle bar
Stock seat --> Custom lowered (DIY) + upholstery touch up($80)
Stock fork --> Andreani (Group) Fork ($1300)
Stock shock
Stock fairing --> DIY black-tinted windscreen($25) + chinese fake carbon rear hugger ($160) + DIY hugger extension ($16) NEW
Stock sprocket --> stock front+44T supersprox rear($150)
Stock levers --> MC short levers (ebay $58)
nethern is offline   Reply With Quote
Old Sep 15th, 2011, 8:46 am   #3 (permalink)
Maximo's Avatar
Voltage was/is good...as indicated by the dash and ext. meter. Had it on a charger for the two hours of tinkering.
I really think it was the key and somehow corrected itself after I used my second key. At one point of running thru the dash menu several times I saw an error message and I think ??? I saw the 4 digit code screen but I was cycling thru it so quick I'm not completely confident.
Based on the iPhone caper I read in the MST thread I'm going to mess around with my iPhone/key exposure and see if there's a correlation.
Anyway, it fired up as usual on the first turn this AM, with both keys, so the ghost has left the machine. if your HM won't start someday put "try other key" on the list of things to try even though it doesn't make much sense.
Old Sep 15th, 2011, 2:19 pm   #4 (permalink)
Decreasing Dave's Avatar
Images: 14
I've had that happen before and I think it was the immobilizer. I had to take the key out and reinsert it for the bike to start.
One thing that I do now is have the key facing the same way everytime and I haven't had a problem since. If you look at the key from the bottom (part that goes into the ignition), you will see a metal "tang" that sticks forward from the "key" part, in the "grip" part. I try to keep the "tang" part forward and all has been well.
Dave
My DOC Welcome Kit
Dave Yeski
CCS Southwest Expert #99
(apparently retired....)
2008 Hypermotard S Black!!!!
2006 Yamaha YZ450F Supermoto
Old Sep 15th, 2011, 2:35 pm   #5 (permalink)
johnchypermotard's Avatar
Dave
silly decreasing dave ... tang is for astronauts ... and the ryans
Old Sep 15th, 2011, 4:00 pm   #6 (permalink)
Maximo's Avatar
Cool, thanks for the info. I will definitely try the consistent key orientation; I was wondering if during my several attempts I put the key in the same way and if that made a difference. At the risk of fouling something again I'm still gonna introduce my iPhone to the circuit just for experimentation... I'll report back.
"vodka and tang... Breakfast of alcoholic astronauts". Anonymous Astronaut
Old Sep 15th, 2011, 4:40 pm   #7 (permalink)
I've had my bike not start on a couple of occasions. I thought it may have been in the ignition switch itself since cycling the key once or twice seemed to do the trick. I'll try to pay more attention if/when it happens again.
I was under the belief that the immobilizer just kept the engine from running. When my bike has acted up it wouldn't crank although all other systems seemed normal.
Rick Yamane
Motion Pro
Ricoyam is offline   Reply With Quote
Old Sep 16th, 2011, 11:50 am   #8 (permalink)
Home of vortex tuning
CDONA's Avatar
My guess that the RFD scanners used for inventory security at the exits of stores may have issues with our "smart" keys too. The immobilizer will kill the starter sequencer only, all other systems work.
Old Sep 17th, 2011, 10:27 am   #9 (permalink)
Maximo's Avatar
Gotta be the same thing... Everything normal but no starter. Is it just a matter of inputting your code if it gets fouled? Really don't want to carry and treat my spare key like a piece of kryptonite in a lead box. still doesn't explain how the key worked later ...after using the second key. Anybody disconnect the immobilizer???
Old Sep 17th, 2011, 3:00 pm   #10 (permalink)
Images: 14
Alex (08Hyper), just cut the wires.
It worked for him. The added benefit is NOW he can spell......
Dave
My DOC Welcome Kit
Dave Yeski
ST3S wouldn’t start... A short story, featuring: CPS/Timing Position Sensor openhead Sport Touring 4 Apr 12th, 2011 5:36 pm
Wouldn't start after a short run TT Tim Sport Touring 1 Jan 29th, 2011 2:33 pm
My bike wouldn't start this morning SP544 HyperMotard 6 Sep 5th, 2009 2:18 pm
Help - My First bike Ducati 749S wouldn't start eddietsuihk Superbikes 9 Nov 11th, 2008 5:57 am
Bike wouldn't start, immobilizer error code 37.1 josephvman HyperMotard 4 Jul 20th, 2008 8:15 pm
