09 hyper front fork ? - Ducati.ms - The Ultimate Ducati Forum
Old Sep 13th, 2011, 1:06 pm   #1 (permalink)
New to the hyper world but not to suspension tuning. Also new to the board, hello....
Picked up a 09 1100 standard and went to dial out some Preload manual says I should have 10mm to play with. When I turn the adjuster in or out nothing happens and then it stops turning but never comes up out of the tube to show any lines.. What's going on here??
Scott
Bourkeco is online now   Reply With Quote
Old Sep 13th, 2011, 2:45 pm   #2 (permalink)
NikMusolino's Avatar
Is it a Kayaba fork? I can't remember if the front forks on the base model are different from the 'S... I know one thing about Mine... When I pulled them off and took them to Race Tech here in SoCal, they remarked upon the fact that they were not Marzochis, but Kayaba.
EDIT: Thanks tkl999. Does the standard even have a ride-height link? So little adjustability, if they don't. Jacking up the rear ride height was one of the best things I did to Mine.
'09 HYM1100S Nero
Old Sep 13th, 2011, 2:48 pm   #3 (permalink)
Kayaba's were on the 09 1100S not the standard. I have the 09 1100 non S model and it has Marzocchi on it.
tkl999 is offline   Reply With Quote
Old Sep 13th, 2011, 3:02 pm   #4 (permalink)
Does the preload adjuster come up out of the tube when you back it out on the marzokies(sp?)
Old Sep 13th, 2011, 3:05 pm   #5 (permalink)
Ben710's Avatar
No, itīs not like on SBK Showas or similar.
Old Sep 13th, 2011, 4:08 pm   #6 (permalink)
So how do you adjust the preload?? The manual says you can!!
Old Sep 13th, 2011, 11:08 pm   #7 (permalink)
Ben710 answered you.
Adjusting the preload wont make the adjuster come up out. It's all internal. So you will never see any lines like the ones you can see on conventional forks.
So the manual is right, preload is the most basic setting on a fork, and every 1100 Hyper can do it.
The manual is false when it shows lines... that part is not true.
Tho, in regard to the Hyper forks, the progressive springs are not the best.
Compression and rebound cartiridges are sealed, making any work in there impossible.
Old Sep 14th, 2011, 7:58 am   #8 (permalink)
Now I get it!! Thanks, yea I heard about the internals..
Oh well it's is part of the fun figuring all this setup and farkel stuff!!
Scott
Thanks all
Scott
Old Sep 14th, 2011, 3:27 pm   #9 (permalink)
JFB1973's Avatar
I think the 09 standard are Showa and not marzocchi, I had this discussion with my dealer and also someone on the forum corrected me, although they are the same setup as the marzocchi... Something liken that ....
JFB1973 is offline   Reply With Quote
Old Sep 14th, 2011, 3:44 pm   #10 (permalink)
07-08
Std : Marzo 50mm
S : Marzo 50mm with gold finish and DLC treatment
2009
Std : Marzo 50mm
S : Kayaba 48mm with gold finish and DLC treatment
10-11
Evo : Marzo 50mm, black anodized upper slider
Evo SP : Marzo 50mm with +30mm fork travel, Black anodized with DLC
Hyper (non S) fork diameter? Chris R. HyperMotard 13 Aug 9th, 2011 8:54 pm
Hyper Fork Solution – Group Buy! bigpuss HyperMotard 228 Feb 23rd, 2011 10:24 am
796 hyper fork oil question el tardo HyperMotard 2 Sep 30th, 2010 1:31 pm
WTB Hyper fork guards thewrx Parts and Accessories 5 Jun 22nd, 2010 4:26 pm
