Sep 8th, 2011, 12:47 am
Extended Member
Technical Q: Hyper vs Hyper EVO dash fitment
So, I was pretty excited about having found a replacement dash for my hyper after buying one from a salvage place together with a new headlight... only to find that this replacement one (from an EVO) didn't fit the fitment from my old bike (2008 Hyper S.)
Am i S.O.L.?... do I try to return it and find a regular hyper dash?.. can i change out the plug? harness?
any technical gurus have any advice on this?
thank you.
Sep 8th, 2011, 4:53 pm
I was waiting for your feedback on that... guess it's not a direct fit in the end.
The way I see it, the cheapest solution to get out of that situation is to sell the new (and beautiful) dash and source a used one from a 08-09 Hyper.
An "elegant" solution would be a siemens ECU with a customed DP profile from Anthony @ desmoworks, with a complete wiring harness.
The ECU should be flashed to a DP one but with the 2x O2 sensor disabled to run an open loop.
Or you could try a dash used with a MM ECU, like, hmmm, a 1098 one
Sep 9th, 2011, 2:10 pm
Extended Member
ok, sent the EVO dash back and waiting for one from an 08 hyper S... very short sighted of me... EVO vs S has dual vs single spark, different ECU (siemens vs magneti?) and a bunch of other differences.. would have never worked.
my only other option is some sort of logitech dash?
Sep 9th, 2011, 2:12 pm
Extended Member
yea but I'm trying to not spend a fortune... If i start messing with wiring harness etc it's a whole different ball game. The salvage place I'm dealing with is supposed to have 2 2008 hypers coming in next week so i should be ok there... will probably have to flash it to get it to work with my ECU but it's an easier proposition. I like the 1098 dash idea but keep in mind how small the space is behind the fairing for a hyper.
Sep 9th, 2011, 2:32 pm
or, the way you like to ride, perhaps THIS option ...
Sep 9th, 2011, 2:37 pm
Extended Member
funny enough, I can't do wheelies but I'm great at having both wheels off the ground
*practicing my painting skills as we speak, don't worry, will look great by sunday
Sep 9th, 2011, 2:43 pm
i do not want my tank cover to look like it was painted by a 'tard
Sep 9th, 2011, 7:20 pm
Never go full MoTard!
