HM is so bad at low rev/speed. Is there a fix? - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGear
Old Sep 6th, 2011, 5:46 am   #1 (permalink)
Every time I am in the car park. It's low end performance really drives me crazy. It just felt like it would stall at any moment.
Does any of you know whether there is a fix for this?
Shorty toetip on a 2010 HM 796 Ducati Red
Stock exhaust/pipe --> LV decat($261)+stock can
Stock air box/filter --> KN filter($64)+Lid removed
Stock rear fender/plate holder --> evotech tail tidy (ebay $104)
Stock mirror/handguard
Stock ecu --> PCV+opt($350)
Stock map --> Dyno map ($350)
Stock handle bar
Stock seat --> Custom lowered (DIY) + upholstery touch up($80)
Stock fork --> Andreani (Group) Fork ($1300)
Stock shock
Stock fairing --> DIY black-tinted windscreen($25) + chinese fake carbon rear hugger ($160) + DIY hugger extension ($16) NEW
Stock sprocket --> stock front+44T supersprox rear($150)
Stock levers --> MC short levers (ebay $58)
nethern is offline   Reply With Quote
Old Sep 6th, 2011, 5:53 am   #2 (permalink)
ECU reflash or seeing that you have a 796 a PCV or Bazzaz might do it.
krisnet55 is offline   Reply With Quote
Old Sep 6th, 2011, 6:08 am   #3 (permalink)
el tardo's Avatar
change your front sprocket from a 15tooth to a 14 tooth and the bike will be like night and day
2010 black 796
dont make me badge you!!
Old Sep 6th, 2011, 9:23 am   #4 (permalink)
romancommander's Avatar
14t helps, only fix is full exhaust, air filter and a reflash or PCV.
09 M1100, Silver and Corse
14t, Sliders, CW tail kit, Custom shaved seat, GPR4 damper, dual stars, ebay levers, battery and cable upgrade.
romancommander is offline   Reply With Quote
Old Sep 6th, 2011, 9:48 am   #5 (permalink)
Moderator
stryder's Avatar
The "Ducati Tax."
Regards,
Frank, '05 ST3, (Red!!)
"Veni, Vidi,....Ducati!!"
stryder is online now   Reply With Quote
Old Sep 6th, 2011, 10:20 am   #6 (permalink)
Can someone describe this "problem"?
I'm looking into the HM796 which will mainly be a daily commuter for me so any slow speed challenges are of interest.
I have not test ridden the bike but any info would be help for me when I do (what to test/check out).
Thanks.
407guy is offline   Reply With Quote
Old Sep 6th, 2011, 10:41 am   #7 (permalink)
Thanks.
A little chugging, surging in the lower rev range due to poor (lean) low rev fueling and tall gearing. Most Ducati's suffer, a 14t sprocket moves the problem to even lower in the rev range where usually you aren't at a part throttle situation (or where you usually have the clutch pulled in) thus pseudo fixing it.
It can be annoying, but not overcome-able with a little extra clutch work. Hell coming from an I-4 600cc machine that required constant clutch modulation its not bad at all.
The real fix is to get rid of the lean condition/poor fueling at the low revs which is the "ducati tax".
Old Sep 6th, 2011, 11:16 am   #8 (permalink)
Great. Thanks for the info.
Old Sep 6th, 2011, 9:01 pm   #9 (permalink)
Images: 3
Read the threads about Ducatidiag. It's a few pages in, but it'll give you the answers to your questions.
Hattmanx
2008 Hypermotard
2001 GSXR1000
1996 ZX-9R
1982 920 Virago
1977-2009 UH-60
HATTMANX is offline   Reply With Quote
Old Sep 7th, 2011, 3:24 am   #10 (permalink)
disgo duc's Avatar
Images: 23
dan kyle throttle tube will make it less snatchier at low speeds...p/c and tuning fuel mixture has alot to do with it as well...welcome to the world of ducatisti!
GPS speed vs. Speedo speed, GT1000 ducatisRme Sport Classic 4 Mar 14th, 2012 9:06 pm
low speed surging and high speed lugging meloman Monster 29 Mar 25th, 2011 9:38 am
ILLEGAL speed trap or just a speed trap sick50ford HyperMotard 27 Jan 31st, 2009 1:20 pm
The Futility of Speed for Speed's Sake Bikehead Sport Classic 12 Dec 18th, 2007 1:09 am
6-speed gear box in a 5-speed case whirlybird Supersport 20 Jan 9th, 2007 11:29 am
