08 Hyper 1100s stalling? - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGear
Old Sep 2nd, 2011, 7:16 am   #1 (permalink)
Wiscy's Avatar
Hey guys as some of you know i just got a bike and so far i put about 600 miles on it and i love it. I have had one problem with it so far and i want to see if anyone else has experienced the same thing. So its only happened twice and both times it came after riding about 100 miles i stop to fill up and after i start the bike and shift into first the bike will shut off. I will do this about 3 to 4 times befor the bike will stay running when i shift it into gear. The clutch seams to be set up fine its not like its trying to take off when i shift it, it just dies. Any ideas?
Experience is something you don't get until just after you need it.
2008 Ducati Hypermotard 1100S.
FULL Termignoni carbon race exhaust with DP ECU and high-flow air filter
Ducati Peformance steering damper kit
Speedymoto open clutch cover and anodized pressure plate
short license plate mount kit, carbon tank pad
Wiscy is offline   Reply With Quote
Old Sep 2nd, 2011, 7:38 am   #2 (permalink)
does it stall if you have it in gear, then pull in the clutch and start it? Does it lurch forward when you try and put it in gear?
2008 hypermotard 1100, 2-1 Termi, Aviacompositi tail, Renthal fat bars, DP seat, Sato rear sets.
-ftp- is offline   Reply With Quote
Old Sep 2nd, 2011, 7:40 am   #3 (permalink)
Wiscy's Avatar
And yes i did do searches in this and i know stalling is an issue with some ducati bikes but they dont sound like the problem i am having, maybe so idk.
Old Sep 2nd, 2011, 7:42 am   #4 (permalink)
Wiscy's Avatar
I start it in neutral shift down to first and it dies no lurch or anything just dies. I can rev the piss out of it and shift, and it still dies....
Old Sep 2nd, 2011, 9:28 am   #5 (permalink)
08hyper's Avatar
If the bike idles fine and when you put it in gear it just dies, the clutch needs adjustment or the kickstand is down. Aloha Alex
Old Sep 2nd, 2011, 9:28 am   #6 (permalink)
From what you're describing, assuming it won't start in gear either, i'd disconnect the kickstand switch to determine if it's bad.
kcasner is offline   Reply With Quote
Old Sep 2nd, 2011, 9:51 am   #7 (permalink)
Wiscy's Avatar
Thanks, guys i will check the kickstand switch
Thoughts on 08 1100s hyper Wiscy HyperMotard 25 Sep 1st, 2011 3:31 pm
F/S 08 Hyper 1100S motard11 Bikes 3 Jun 12th, 2011 11:03 pm
Hyper 1100s vs. Aprilia SXV 550 SilverTT HyperMotard 207 Jan 21st, 2010 12:00 am
New HM 1100S (600KL) Stalling and Jerking at 2000rpm ABL HyperMotard 12 Oct 16th, 2008 8:00 pm
