FNG questions Ohlins preload and flush indicators - Ducati.ms - The Ultimate Ducati Forum
Graves Motorsports
SportbikeTrackGear
Old Aug 31st, 2011, 7:27 am   #1 (permalink)
Hilly's Avatar
Just joined the Ducati family with a 2010 1100 sp Hyper
The shop did not have the tool to adjust the preload on the rear shock. I am 105kg so want to wind it up a bit; any how to's out there? Tool needed and what to remove to get in. Don't want to use a hammer on it.
Has anyone put flush indicators on the fairing? Want to ditch the original setup. Hoping to put them on the little scoops.
Thanks in advance
Cheers Andrew
Hilly is offline   Reply With Quote
Old Sep 1st, 2011, 11:44 pm   #2 (permalink)
nickd64's Avatar
Hi Andrew
You will need a C spanner to adjust the ring nuts on the shock. Surprised dealer does not have one?
But you are probably wasting your time trying to set preload on a standard spring given your weight. Standard spring is rated for approx 70kg rider...
My weight is 100kg without riding gear, so I have replaced the standard Ohlins spring with a heavier unit to sort out rear spring rate & preload. Part number I have is 01092-49/130.
This has made a significant difference to the bikes handling. You will also probably want to consider heavier springs for the forks also.
Troll around on this forum as there is plenty of info posted about setting up Hyper suspension.
Nick
Nick - 2008 Hypermotard S
nickd64 is offline   Reply With Quote
Old Sep 2nd, 2011, 8:08 am   #3 (permalink)
Hilly's Avatar
Thanks for the info Nick.
So the Evo is the same as the 08 suspension wise? Have searched and all the posts are for 08's no info for Evo Hypers.
Bump on the indicators :-)
Cheers Andrew
Old Sep 4th, 2011, 4:40 am   #4 (permalink)
nickd64's Avatar
Pretty sure they have the same rear shock & spring set up. The SP is slightly taller with more suspension travel, 11mm.
Ohlins rear preload adjustment flyinlow1 StreetFighter 8 May 24th, 2012 10:34 am
Traxxion preload collar for '08 S Ohlins? vulpine3 HyperMotard 1 Jan 20th, 2011 3:45 pm
Ohlins fork preload question AreWeNotMen? Monster 18 Mar 12th, 2010 6:40 pm
WTB Ohlins Preload Black KNob ColinF Parts and Accessories 0 Jan 3rd, 2010 12:29 am
Flush mount indicators mals900ss Supersport 12 Apr 9th, 2006 7:56 am
