Aug 29th, 2011, 6:03 pm
Termi Install Help
Hey guys, for anyone that has installed the Termi 2 into 1 onto an Evo (kit should be similar to 08 model as well), just have a couple of install questions;
1. When mounting the exhaust hanger and rear under-tail, did you just bolt straight up to the rubber mounts, or use one of the plastic or metal collars inside the rubber mount. (the rubber mount was originally used to hold the exhaust valve motor)
2. Mounting the rear carbon covers, looks like s spacer is required on the front of the panel. But dont seem to have any in the kit, or are you supposed to use the papery washers with one of the plastic collars?
Also wondering what bolt to use as none of the ones I have seem to fit, other than the original, but they dont seem long enough.
I did buy the kit second-hand, so wondering if some bits are missing.
Would be great it someone could post a pic of the top and bottom of the tail with the seat off.
Thanks guys.
Aug 29th, 2011, 7:15 pm
ciao jono1000,
the DP termi 2-1 installation PDF is located here
this PDF has colour photos of the installation steps.
ciao,
johnc
Thanks guys.
Aug 29th, 2011, 9:40 pm
Thanks Johnc, I do actually have a copy of that, but just wondering if I am missing parts from the kit, or that those particular parts are different between the 1100 Evo and 1100 models.
If anyone with an EVO and 2 into 1 might be able to check what sort of spacer was provided?
Cheers
Aug 29th, 2011, 11:38 pm
I installed my Termi 2-1 couple of wks ago and had a hard time guessing the bolts and washers and collars as the instructions were pretty crappy. Never the less, my patience paid off and hope the pics can be of help to you.
To answer Q1: the kit comes with 2 alloy collars, use them to insert thru the rubber thingy( whatever you call that)
To answer Q2: the picture speaks for itself.
Aug 31st, 2011, 1:05 am
Awesome thank you so much for the pics.
I did actually end up installing it as you have shown in the pics. So least now know got it right.
Only thing i didnt do was use the collars in the exhaust hanger, so might fix that up.
Thanks again!
