My HM is no longer a virgin - Ducati.ms - The Ultimate Ducati Forum
Old Aug 29th, 2011, 4:10 pm   #1 (permalink)
LeFauxTard's Avatar
Did my first minor mod with only 12 miles on the odometer.
I just could not stand the look of the fugly evap canister mounted
on that cheap bracket.
So I gave my bike a evapcanisterectomy.
(See attached photo of extracted organ)
LeFauxTard is offline   Reply With Quote
Old Aug 29th, 2011, 4:15 pm   #2 (permalink)
nyandy's Avatar
nice. i was told that throws a code. true? was it just a removal or did you have to cap off anything?
nyandy is offline   Reply With Quote
Old Aug 29th, 2011, 4:24 pm   #3 (permalink)
Gilly's Avatar
Images: 17
Typically you would cap off the leads to the throttle bodies or cap off the nipple that is at the base of each throttle body... So three choices. Cap the single lead from both TB's. Cut and cap each lead separate (so you can perform TB sync later in life). Remove all and cap the nipple at the TB base.
Secondly, reconnect the lead from the tank that hooked to the top of the evap can, to the bottom piece coming out of the bottom of the evap can. This ensures any overflow is dumped below the engine... The fuel tank still has to breathe. A simple straight hose connector works fine for this.
At least that is how I've done mine.
"Oh My!" thread link... FFS!
Old Aug 29th, 2011, 5:28 pm   #4 (permalink)
LeFauxTard's Avatar
I used vacuum caps and capped the nipple at the base of each throttle body.
I left the vent hose from the gas tank (after cutting it at the canister) hang down and secure it with a zip tie
to the other hoses at the bottom.
I didn't get the chance to start the bike after the procedure.
Old Aug 29th, 2011, 7:45 pm   #5 (permalink)
nyandy's Avatar
Thanks for the info guys. Can you let me know if it does show a code after you start it back up? Thanx.
Old Aug 29th, 2011, 9:40 pm   #6 (permalink)
Did mine exactly the same. It will NOT throw a code.
Seven9Six is offline   Reply With Quote
Old Aug 29th, 2011, 9:56 pm   #7 (permalink)
nyandy's Avatar
Decent! Thanks seven9six! Going to get rid of mine as well.
Old Aug 29th, 2011, 10:33 pm   #8 (permalink)
Extended Member
CAlexio's Avatar
nice to meet you tonight Adrian, enjoy your new ride!
Old Aug 29th, 2011, 11:38 pm   #9 (permalink)
LeFauxTard's Avatar
Likewise Alex!
Nice avatar by the way ;-)
Old Aug 29th, 2011, 11:42 pm   #10 (permalink)
LeFauxTard's Avatar
After talking to johnchypermotard, I decided to replace the nipples on the throttle bodies with screws to prevent vacuum leaks.
Thanks John!
WTB virgin 749 or 749 s 03,04 ecu robob Parts and Accessories 2 Sep 16th, 2010 3:27 pm
No longer a slipper clutch virgin & which STM? .android. Superbikes 7 May 19th, 2010 6:11 pm
Bike virgin - Ducati virgin JacksonPollock Welcome and Introduction 1 Apr 28th, 2010 8:33 am
how to determine if a dp ecu is virgin? auto3251 Superbikes 2 Dec 9th, 2008 5:50 am
Another D#@mn Virgin needs Help! Michael Lee Supersport 2 May 23rd, 2008 3:11 pm
