Technical Q: putting EVO SP forks on std "S" bike - Ducati.ms - The Ultimate Ducati Forum
Old Aug 25th, 2011, 12:56 pm   #1 (permalink)
Extended Member
CAlexio's Avatar
I have the opportunity to buy some EVO SP forks to fit to my hyper rebuild.
any idea if I can just swap these over with my stock triples and brake caliper carriers?... my concerns are whether these forks are the same diameter, and whether I need an additional rear linkage or something on the rear suspension to make these taller forks work.
thanks for any knowledgeable advice.
Old Aug 25th, 2011, 4:04 pm   #2 (permalink)
08hyper's Avatar
Good question, I would start by compairing part #'s from your bike with the EVO SP, such as rear shock, frame, linkage, thriple clamps, calipers, etc.etc. Aloha Alex
Old Aug 25th, 2011, 5:46 pm   #3 (permalink)
Decreasing Dave's Avatar
Images: 14
I think the forks will work but you need to find out what you have to do to the rear to get the "SP Stance".
More ground clearance should work well for you if you go off the road again.......
Dave
My DOC Welcome Kit
Dave Yeski
CCS Southwest Expert #99
(apparently retired....)
2008 Hypermotard S Black!!!!
2006 Yamaha YZ450F Supermoto
Old Aug 25th, 2011, 5:53 pm   #4 (permalink)
johnchypermotard's Avatar
now THAT was funny
Dave
Old Aug 25th, 2011, 10:23 pm   #5 (permalink)
I'm 99% sure the forks are the same, only the travel is 30mm bigger.
Inner tubes remain 50mm, outer tubes are 57mm - 53mm, which makes them a direct fit into your S clamp.
Brake caliper carriers are 100mm, your Brembo Monobloc are direct fit too.
Dunno what price you can get on them, hopefully a deal as good as the one you had on your wheels
But from what I remember, someone in Montreal wanted to buy an Evo SP and swap the fork with the NCR fork.
I told the dealer I was interested by the SP fork. When I saw the price, changed my mind.
A 46mm Ohlins with forged clamps is cheaper...
Old Aug 25th, 2011, 11:13 pm   #6 (permalink)
Extended Member
CAlexio's Avatar
Dave
some day "dave" we shall meet, and there will be payback for all the "hasslin' " you give me over one innocent little "off" that i was waaay too honest about in describing. in the meantime, lets see if I can gather some REAL info!
Originally Posted by johnchypermotard View Post
now THAT was funny
ET TU BRUTE!?!?!?!?! (gd backstabber)
thanks, it definitely is price-dependant, but I found a guy who has a salvage EVO SP, and while im purchasing the dash and a few other parts I'm checking on the forks just in case. would love to have a bit more ground clearance...(for when I go off road)
Old Aug 26th, 2011, 11:36 am   #7 (permalink)
If you're looking for more ground clearance, then it's one way to do it for sure!
Another way would be the Race Tech cartridges, which can add an extra 10mm of travel.
A freaking awesome way would be a Marzocchi Shiver 50 USD from the dirt world with adapted fork bottom... That would give you offroad fun
The rear height can be adjusted on the S with the adjustable link.
I dont think the shock on an Evo SP is any different than the one you have on your S
You got his dash from an evo sp to fit on your S ? Does it work ?
I'm very curious to know about that !
Old Aug 26th, 2011, 12:56 pm   #8 (permalink)
Extended Member
CAlexio's Avatar
good point about the dash, don't know. I've been told I have to reflash the whole thing, why would an EVO be different from an S? it's actually been pretty tough getting good solid answers on how to get a new dash for this bike.
Old Aug 26th, 2011, 2:20 pm   #9 (permalink)
si ... it was funny
Suspension Spring Rate, Forks-Shock "Balance" konstantin690 Supersport 2 Sep 14th, 2010 10:41 am
96 "terrible Marzocchi forks" nicky k Supersport 16 Jul 9th, 2009 2:02 pm
900ss '97 i'm looking for "clear front turn covers" and "frame slider kit" pompone italy Supersport 9 Aug 12th, 2008 10:17 pm
"Ducati hits the AutoBlog" or, "Fanning the Flames of the redesign rumor mill" fasterdammit Monster 4 Oct 1st, 2007 8:23 pm
