916 front wheel in Hyper? - Ducati.ms - The Ultimate Ducati Forum
Old Aug 23rd, 2011, 5:58 am   #1 (permalink)
Ben710's Avatar
A standard 916 front wheel would fit the Hyper by axle diameter, thatīs how far I have come. But I am puzzled by which brake discs (6 hole) I would have to use to get the same offset as the Hyper brake discs.
Hypermotard and all 999 onwards have 5 holes, 916 has 6 holes.
Does anyone have a clue?
Old Aug 23rd, 2011, 8:27 am   #2 (permalink)
bamabytes's Avatar
Pretty sure the offset is wrong, also there is a manual speedo on the 916 series of bikes.
You may want to contact Nick at Motowheels. They are also a site sponsor. He helped me figure out which wheels fit what a few months ago.
Seven-Hundred-Forty-Eight CC's is my traction control.
bamabytes is offline   Reply With Quote
Old Aug 23rd, 2011, 7:55 pm   #3 (permalink)
el tardo's Avatar
you can make any wheel fit with the right spacers as long as the axle diameter is the same size.
2010 black 796
dont make me badge you!!
Old Aug 24th, 2011, 12:49 am   #4 (permalink)
Ben710's Avatar
You might want to reread the question...
Thanks mate, the speedo is not an issue. It can be removed. A 999 front wheel should fit straight away, so Iīll try that.
wtb: 848/1x98/hyper/749/etc...front wheel xr1owner Parts and Accessories 1 May 13th, 2011 10:27 pm
Hyper Front Wheel Install/Setup Question Steve C HyperMotard 16 Nov 26th, 2010 6:43 pm
1198 rear wheel front wheel and sprocket nut sizes?? colyn Superbikes 2 Jun 16th, 2010 11:19 am
WTS Black Front & Rear 2008 Hypermotard Wheels; WTB BST 5-Spoke 749/999 Front Wheel Supero100 Parts and Accessories 1 Feb 23rd, 2010 8:19 pm
Front wheel change! will a 999 wheel work? colinatx Multistrada 3 Oct 1st, 2009 8:59 pm
