Would bad gas (or water in the gas) prevent starting? - Ducati.ms - The Ultimate Ducati Forum
Old Aug 22nd, 2011, 11:41 am   #1 (permalink)
Rob H's Avatar
Can't get it started...
Not to sound dumb... but my Hyper didn't start this morning, and I'm grasping at straws here.
The bike just had its 7500 service a couple weeks ago and got a clean bill of health. I rode it to and from work without issue for two weeks. I gassed up Friday morning, rode to work and back home, and then parked it for the weekend. I tried to start it this morning, and no go. It cranks like a champ, sounds like it wants to start, but then doesn't. I tried about 15 times before giving up and taking the car.
Would water in the gas completely prevent it from starting? I'm thinking of dumping the gas (once I figure out how to do that) when I get home...
I'm open to any suggestions!
Thanks!
'08 Hyper 1100
'07 DR-Z400SM
Rob H is online now   Reply With Quote
Old Aug 22nd, 2011, 11:45 am   #2 (permalink)
Nginear's Avatar
Have you checked the fuse for the fuel pump? Maybe when you turned it on this morning it popped it. So she'll crank but not fire.
'10 hyper 796
'06 KTM 450exc(Plated)
'03 TTR-125
Nginear is offline   Reply With Quote
Old Aug 22nd, 2011, 3:54 pm   #3 (permalink)
Rob H's Avatar
That actually makes more sense. I'll check. Thanks!
'08 Hyper 1100
'07 DR-Z400SM
Old Aug 22nd, 2011, 8:23 pm   #4 (permalink)
Rob H's Avatar
Fuse is fine. Still not starting... >
'08 Hyper 1100
'07 DR-Z400SM
Old Aug 22nd, 2011, 8:36 pm   #5 (permalink)
el tardo's Avatar
1.pull plugs and check for spark
2.could be tps out of whack
3.valves to tight
4. are the injectors firing? on some cars you could hold throttle wide open and it would make it fire up
i had bad gas two yrs ago in a bike and it would start but would stall out,happened twice from same gas station so i stopped going there.
sucked trying to figure that one out and i thought i killed my bike
2010 black 796
dont make me badge you!!
Old Aug 22nd, 2011, 9:36 pm   #6 (permalink)
Rob H's Avatar
I'll have to give it another try tomorrow night. The battery needs to charge after all the attempted starts.
After reading about a million posts, I tried whacking the throttle while holding the starter button. It would actually get to a rumbling idle for a few seconds and then die. A couple of times it seemed like it was going to keep running, but no luck. I tried holding the throttle wide open as well, with similar results. It would rumble for a little while, then die.
I also tried turning my Fatduc to full lean (as someone had a similar problem that was caused by the Fatduc), but it didn't help. I'll pull a plug tomorrow night to check for a spark...
I did shake the bike for a while (I must have looked like a maniac) to stir up the gas in the tank, and it seemed to help a bit...
I really hope 2. and 3. aren't the case as it just got its service...
'08 Hyper 1100
'07 DR-Z400SM
Old Aug 23rd, 2011, 7:28 am   #7 (permalink)
Rob H's Avatar
I pulled a plug and confirmed she's got a spark. Still won't start.
'08 Hyper 1100
'07 DR-Z400SM
Old Aug 24th, 2011, 1:52 am   #8 (permalink)
jump timing?
ludenukka is offline   Reply With Quote
Old Aug 24th, 2011, 7:07 am   #9 (permalink)
Rob H's Avatar
I'm starting to think that may have happened. It's at the dealership now... Fingers crossed it doesn't need anything shipped from Italy...
'08 Hyper 1100
'07 DR-Z400SM
Old Aug 24th, 2011, 12:15 pm   #10 (permalink)
Rob H's Avatar
And the verdict is in: New fuel filter installed during service has cracked/split. New new filter in place, and all is well.
'08 Hyper 1100
'07 DR-Z400SM
Best coolant? Engine ice vs water wetter vs distilled water and etc LD_DUCATI Superbikes 7 Jun 2nd, 2011 9:08 pm
Prevent Melting, Get New Summer Gear RevZilla RevZilla.com 0 Jul 8th, 2010 10:32 am
black anodize fading? Anyway to prevent this? rustysrustyduc Superbikes 9 Feb 9th, 2007 5:12 pm
Proper ratio for water wetter, coolant and water Ducwizard Superbikes 9 Aug 21st, 2006 10:19 pm
Gloves to prevent Carpal Tunnel JuniorinTulsa Sport Classic 0 Jul 13th, 2006 8:50 pm
