More clutch woes: Help, please. - Ducati.ms - The Ultimate Ducati Forum
Old Aug 21st, 2011, 3:42 pm   #1 (permalink)
DrJ
DrJ's Avatar
Ever since I installed my EVR slipper clutch, EVR clutch slave (30mm), & my Pazzo clutch lever on my 2010 Evo Sp, I have had continuing clutch issues. It started a few weeks after the aforementioned installation. Here's what happens: I start up the bike in neutral, pull in the clutch lever, put it in gear, and the bike lurches and then stalls out.
I brought it to the dealer and they said there was air in the clutch master. They bled it, it worked for a week, and then problem re-surfaced. I bled it again, it worked for a week, and then the problem re-surfaced.
A buddy of mine said it was the EVR clutch slave. So, I removed it this afternoon, re-installed the OEM one, bled the system, but the problem won't resolve itself at all now. Another buddy of mine thinks I have a defective seal in the Brembo clutch master...
Anybody have a similar problem or have any ideas? If not, it looks like I'll be buying an upgraded Brembo clutch master....
DrJ
2010 Hypermotard Evo Sp (red, of course)
2009 Triumph Speed Triple (flat black)
2007 Segway
DrJ is offline   Reply With Quote
Old Aug 21st, 2011, 4:17 pm   #2 (permalink)
08hyper's Avatar
Since you keep getting air into the system, and your sure its not the slave, then it has to be the Brembo master, bleed fitting, or hose connectors. Make sure all is tight. Aloha Alex
Old Aug 21st, 2011, 4:39 pm   #3 (permalink)
johnchypermotard's Avatar
agreed!!!
fwiw, i am going through same issues with my evr slave cylinder now, and will work on troubleshooting the issue this week to resolve.
Old Aug 21st, 2011, 4:54 pm   #4 (permalink)
DrJ
DrJ's Avatar
Originally Posted by johnchypermotard View Post
agreed!!!
Please let me know what you find out. Thanks.
2007 Segway
Old Aug 21st, 2011, 6:02 pm   #5 (permalink)
will do ... i am going to try and borrow a "good" master, then test the system.
if the air issue goes away, then it was the master ... if not, then it is either the slave or the line.
Old Aug 22nd, 2011, 10:56 am   #6 (permalink)
Seeing you changed the levers, the adjustment of rod from the lever to the master cylinder could be off.
Ted
r60slash5 is offline   Reply With Quote
Old Aug 23rd, 2011, 11:46 am   #7 (permalink)
DrJ
DrJ's Avatar
Well, I got it all sorted out. Once again, some of the clutch friction and steel plates rusted together. The cluprit was washing my bike! Anyway, once the rust occurs, the clutch doesn't work, and it also somehow burps air into the system. The temporary fix is wire brushing the plates and bleeding the clutch fluid.
So, how do you guys avoid this problem? Do you not wash your bikes?!
Thanks.
DrJ
2007 Segway
Old Aug 23rd, 2011, 12:19 pm   #8 (permalink)
Chilehead
st2lemans's Avatar
Images: 74
Actually, I don't (well, maybe once a year or so).
Tom
1985 LeMans
1986 LeMans w/ sidecar
1992 XV250
1998 ST2
2003 SS1000DS
2003 999R #29
www.motogiro.com
st2lemans is offline   Reply With Quote
Old Aug 23rd, 2011, 2:38 pm   #9 (permalink)
Decreasing Dave's Avatar
Images: 14
After washing, start the bike and run it for a bit to get it warm. While it's running, cycle the clutch lever several times to cycle the plates. This will help expell the water from the clutch plates. The warm motor/exhaust will help evaporate any puddles that form on the engine or in the exhaust.
Dave
My DOC Welcome Kit
Dave Yeski
CCS Southwest Expert #99
(apparently retired....)
2008 Hypermotard S Black!!!!
2006 Yamaha YZ450F Supermoto
Old Aug 23rd, 2011, 6:58 pm   #10 (permalink)
Originally Posted by Decreasing Dave View Post
The warm motor/exhaust will help eveaporate any poodles that form on the engine or in the exhaust.
Dave
wow ... first unicorns ... and now poodles?
Clutch woes Again! Need advice acoolsubi HyperMotard 7 Jan 20th, 2011 12:20 am
999 woes.... Blurrrrrrrr.... Superbikes 19 May 3rd, 2009 6:16 pm
Starting woes GreyDuck Sport Classic 21 Jan 30th, 2009 11:40 am
Clutch woes dzucati999r Superbikes 13 Feb 10th, 2008 8:24 pm
95 900ss clutch woes.... macop1104 Supersport 8 Sep 20th, 2007 8:25 am
