more power??? - Ducati.ms - The Ultimate Ducati Forum
Old Aug 21st, 2011, 12:09 am   #1 (permalink)
more power???
In Mexico City i'm down about 30% in power due to altitude. Are there any engine mods that can get me a little bit back? I have Termi 2-1-2 and ECU.
It will not pull the front wheel up without some coaxing in first gear.
'02 1450cc Sportster
'10 BMW F800R
'11 Hyper EVO SP
canicoll is offline   Reply With Quote
Old Aug 21st, 2011, 1:16 am   #2 (permalink)
08hyper's Avatar
Make sure the spark plug is working in the 2nd cylinder, that should help. Aloha Alex
Have it mapped on a dyno for your climate.
Old Aug 21st, 2011, 2:23 am   #3 (permalink)
Decreasing Dave's Avatar
Images: 14
What altitude are you?
I'm at 4600' MSL and I can power wheelie second and back with the stock exhaust, even third.
Maybe too much of the traditionally bad, Mexican fuel??
Dave
My DOC Welcome Kit
Dave Yeski
CCS Southwest Expert #99
(apparently retired....)
2008 Hypermotard S Black!!!!
2006 Yamaha YZ450F Supermoto
Old Aug 21st, 2011, 3:42 am   #4 (permalink)
Extended Member
CAlexio's Avatar
Dave
yes, this seems more like a personal problem with not being able to get it up. . Add some tequila to your, uhm, "gas tank" which will help you get it up and stay up.
Old Aug 21st, 2011, 11:36 am   #5 (permalink)
Mexico city is at an altitude of 7,350 ft or 2,240 meters.
RamIt is offline   Reply With Quote
Old Aug 21st, 2011, 11:54 am   #6 (permalink)
Ported heads with the DP cams and an TPO intake kit and you pickup a bunch.
www.Shift-Tech-Carbon.com
Shift-Tech-Carbon Performance- High Quality Carbon Products!
Shift-Tech is offline   Reply With Quote
michelin power pure vs power one ed218 Superbikes 3 May 20th, 2011 9:58 pm
michelin power pure fr./power 2ct rear combo wyoduc916 Superbikes 5 Apr 25th, 2011 9:24 am
Tires for first track school :: Power 2CT or Power One? mito_gp Superbikes 19 Sep 12th, 2009 7:30 am
Michelin Pilot Power CT2 or Power Race cuvi Superbikes 11 Aug 31st, 2009 10:48 am
TIRE RECALL - Pilot Power / Power 2CT srg5150 Superbikes 28 Nov 18th, 2008 11:35 am
