fork mounts for turn signals?? - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com Classifieds!Motorcycle.comSportbikeTrackGearGraves Motorsports
Old Aug 16th, 2011, 9:01 pm   #1 (permalink)
Looking to ditch the handguards/mirrors/signals combo, anyone know of a company that makes a good quality aluminum clamp to fit the evo sp's forks that will accept a rizoma signal? Looking for something in black anodized or just raw aluminum. I looked around online but after an hour of searching I thought that this has probably already been solved here
jenner is offline   Reply With Quote
Old Aug 16th, 2011, 9:26 pm   #2 (permalink)
goin2leaveamk's Avatar
I have been running these and they are great. They don't clamp to the fork but might be an option$24.00
Rizoma Turn Signal Adapters for Ducati Hypermotard
[FR411B]
These adapters will let you mount front turn signals on the Hypermotard for a much cleaner look after you've changed mirrors. These adapters use the lower side fairing mounting bolt.
These adapters may also be used for other applications.
MSRP: $29
Installation Note: A longer bolt may be required to replace the OEM fairing mount bolt when installing these adapters.
Note: Don't worry about the placement of the signals. They are quite visible, even from across an intersection (they can be seen through the forks). Rizoma signals throw so much light, they are visible from afar, even though these adapters mount them lower than usual.
Add to Cart
Reviews
goin2leaveamk is online now   Reply With Quote
Old Aug 16th, 2011, 9:47 pm   #3 (permalink)
Thanks, I might just have to order a set of those until I can find a fork clamp Really want the signals mounted just off the side of the very top of the forks and I dont wanna go with a drop mount off the bars. I've been still looking since I posted this thread and I can find clamps but only in nasty chrome and chrome is a definite no go for me.
Old Aug 16th, 2011, 11:58 pm   #4 (permalink)
Banned
Images: 19
Wild Hair Accessories do a couple of styles that could be suitable - Head Lights. Wild Hair Accessories. Motorcycle Accessories & Aftermarket European Parts.
Scroll down the page to 'Turn Signal Brackets'.
Or you can try what I did but it's a bit more complicated. - New Mirrors and Turn Signal Relocation
Tard is offline   Reply With Quote
Old Aug 17th, 2011, 12:58 am   #5 (permalink)
Here's what I did. A few minutes with the lathe and belt sander. I have an '08 1100S so may have different forks from you but it's an adaptable concept.
Also, if you can handle it :-) check some of the custom catalogues. Several have universal brackets, usually in steel that you can use. Paint is cheap.
fork mounts for turn signals??-018.jpg   fork mounts for turn signals??-023.jpg
Rick Yamane
Motion Pro
Ricoyam is offline   Reply With Quote
Old Aug 17th, 2011, 5:06 am   #6 (permalink)
Wow, nice one there. If only i have seen it earlier. I wanna to fix a projector light. In the end i got the rizoma turn signal bracket and mount them out. Turn the the forks block certain percentage of the light throw. But still manageable. ^_^ as i dont blind oncoming traffic.
Honda Phantom 200cc 2006 --->2007
Honda Super Four 400cc 2007--->2008
Kawasaki Concours 1400cc 2008 --->2010
Yamaha X1R 135CC - 2010 ---> 2011
Honda PCX 125CC - 2011 ---> 2011
Kymco Myroad 700I - 2011 --- >
Ducati Hypermotard 1100 EVO - 2011--->
ohayo is offline   Reply With Quote
Old Aug 17th, 2011, 5:10 am   #7 (permalink)
minusone's Avatar
You get a dirt bike headlight that has the rubber forkstrap mountings.
Remove these from the light and drill out the hole in the rubber to suit your blinkers.
Safe, flexible and easily removable.
[ Current Rides ]
Gas Gas Raga Replica
Husky TE450
KTM 690 Enduro Rally Raid
Hypermotard 1100S
Multistrada 1200S
Old Aug 17th, 2011, 7:55 am   #8 (permalink)
ccemn1's Avatar
I went with signals integrated into clamp on mirrors. I didn't like the hand guard arrangement either. I didn't want to use bar ends, because I use a Throttle Meister cruise control.
ccemn1 is offline   Reply With Quote
Old Aug 17th, 2011, 7:58 am   #9 (permalink)
ccemn1's Avatar
Minusone, What kind of tail bag/box is that on your bike? The cleanest, sharpest one I've seen!
Old Aug 17th, 2011, 3:43 pm   #10 (permalink)
minusone's Avatar
Yeah everyone asks about that one.
Advertised as "exclusively for BMW motorcycles" but"I think not.
rear seat storage bag pod sleek soft bag touring commuting
fork mounts for turn signals??-g-medium-.jpg   fork mounts for turn signals??-t-medium-.jpg
[ Current Rides ]
Husky TE450
Hypermotard 1100S
Multistrada 1200S
New CNC Rear Light/Turn Signal Unit… Fits OEM Mounts poolagent Sport Classic 16 Mar 25th, 2012 9:14 am
FS LED turn signals Adirondackbob Gear 0 Dec 13th, 2010 1:26 pm
New turn signals for my 748 roeabs Superbikes 0 Oct 22nd, 2007 9:57 pm
Turn signals skorichmonster Monster 10 Oct 10th, 2006 9:58 am
Need help with my 749 turn signals.... skeezer541 Superbikes 3 Jun 12th, 2006 9:39 pm
