Slip on ECU vs Dealer - Ducati.ms - The Ultimate Ducati Forum
Old Aug 11th, 2011, 9:02 pm   #1 (permalink)
shovel383's Avatar
So after hours of deliberation and reading on this forum I decided to install a Zard header to match my Top Gun slip on. To account for the removal of the O2 sensor and flapper I also bought a DP slip on ECU, part number 96519308B. Everything I read here made me believe that this ECU could be set up to eliminate both.
I got everything installed, loaded the Hyper in my truck and drove 90 miles to the nearest dealer. The TPS reset was easy but they could not clear the EXVL and O2 sensor codes. I told them of my vast knowledge of this ECU and that those could be "programmed" out. No luck. When I returned home I plugged the O2 sensor and flapper back in and the dash lights and codes went away.
Question is, did I not understand what I read (I reread after returning home so I don't think that is the case, but I've proven to be not so swooft before) or is this dealer just not knowledgeable enough to make the changes? Is this the kind of thing only a re-flash can fix?
All thoughts welcome....
2008 Hyper
1999 900SS
shovel383 is offline   Reply With Quote
Old Aug 11th, 2011, 9:08 pm   #2 (permalink)
Gilly's Avatar
Images: 17
I think you may have wanted the DP Full 2-1-2 ECU.
That is the flash I put to my stock ecu and I have no problems...
Thanks DucatiDiag and JP, viva la France!
"Oh My!" thread link... FFS!
Old Aug 12th, 2011, 9:49 am   #3 (permalink)
shovel383's Avatar
That is definitely one solution. Guess I can watch the classifieds for one I feel like paying for. In the mean time I can live with the CEL or fabricate a stop bar for the flapper motor.
2008 Hyper
1999 900SS
Old Aug 12th, 2011, 10:06 am   #4 (permalink)
NYSport's Avatar
Images: 4
I believe that you can have your stock ECU re-flashed with a custom map. That was not always the case but within the last year or so the technology has been developed to re-flash stock ECU if they are in working order. They can turn off the flapper/O2 lights with an upgrade re-flash.
http://www.desmoworks.com/ducati-ecu...ens-p-652.html
Old Aug 13th, 2011, 1:56 am   #5 (permalink)
Gilly's Avatar
Images: 17
I didnt buy a new ecu, I reflashed my stock ecu using DucatiDiag Writer software. Total cost was about $180.
I did a write up on it on the SF board. So in essence, you can flash the slipon ecu to full DP status. OR if the ECU was not married to the bike, put the stock one back on, flash it, then resell the slipon ecu to make back some spent money.
Oh My!
Old Aug 15th, 2011, 8:19 am   #6 (permalink)
shovel383's Avatar
I read part of that thread a few weeks ago and it does sound like a good option. I'll re-read it more detail this time. Thanks Gilly
2008 Hyper
1999 900SS
Gift from my Dealer ( Ducati Dealer) JFB1973 HyperMotard 14 Jan 4th, 2010 10:40 am
Best dealer to buy from? BITURBOAMG Ducati Motorcycle Chat 9 May 26th, 2008 11:34 am
Termi slip on or shark slip without changing ECU elementfmfl Sport Classic 4 Dec 31st, 2007 7:47 pm
To slip or not to slip...Clutch advice DesmolitonMan Superbikes 18 Jul 16th, 2007 2:30 pm
New Slip ons + PCIII; do I really need to go to a dealer? kurtfriedrich Superbikes 10 Feb 4th, 2007 10:32 am
