Aug 5th, 2011, 4:16 pm
Hyper Brake Pedal change
So i scraped up my brake pedal by leaning the bike to hard. Bought a new one but dont really know how to get the old one off. Released the single screw but can't pull it off.
Any advice is appreciated
"Always walk through life as if you have something new to learn and you will"
-Vernon Howard
Currently riding
2008 Ducati Hypermotard 1100 "Burrita"
2009 CBR600RR
Previous bikes,
2003 Honda CBR600RR
2004 Suzuki GSX-R750
Aug 5th, 2011, 5:02 pm
Tap a flat head screw driver into the split that the screw tightens together.
'10 hyper 796
'06 KTM 450exc(Plated)
'03 TTR-125
Aug 5th, 2011, 6:40 pm
K thanks. But I was more worried about the fact that the rod the pedal sits on is spring loaded?? wont it rebound?
-Vernon Howard
Currently riding
2009 CBR600RR
Previous bikes,
2003 Honda CBR600RR
Aug 5th, 2011, 6:49 pm
man ... that's just downright mean.
you forgot to mention the brake return spring, which can really cause some issues if not taken care of before removing the rear brake pedal.
see attached exploded view from hypermotard parts manual.
you need to make sure that you remove item #'s 8, 10 and 11, and have item #37 secured (either by a vise grip or a friend holding it), so when you remove item #24 (the pedal), the spring (item #30, does not spin item # 37 into space (or your engine case).
Aug 5th, 2011, 8:17 pm
Thanks Johnchypermotard. Thought there was more to it than that. Im new to this forum but just looking for advice not destroy my bike because some a$$ thinks its funny.
-Vernon Howard
Currently riding
2009 CBR600RR
Previous bikes,
2003 Honda CBR600RR
Aug 5th, 2011, 8:46 pm
Sorry, didn't mean to come off that way. I thought your brake lever was "stuck" on the shaft.
'10 hyper 796
'03 TTR-125
Aug 7th, 2011, 12:54 am
It's cool thanks.
-Vernon Howard
Currently riding
2009 CBR600RR
Previous bikes,
2003 Honda CBR600RR
Aug 7th, 2011, 1:08 pm
i was kidding ... no worries ... i realize you were trying to assist.
Aug 7th, 2011, 1:30 pm
Banned
Pull the bolt all the way out too.
Aug 8th, 2011, 8:50 pm
If the pedal is stuck on the shaft instead of using using a screw driver. Take the bolt out. Insert a washer in the slot in the pedal thread the bolt in the
opposite direction. and tighten it on the washer. It's alot better way to open it up, no marks, and better control.
Ted
