796 throttle mounting? - Ducati.ms - The Ultimate Ducati Forum
Graves MotorsportsMotorcycle.com Classifieds!Motorcycle.com
Old Aug 3rd, 2011, 5:49 pm   #1 (permalink)
I'm trying to mount these to allow some aftermarket mirrors which I've settled on:
http://www.pjsparts.com/catalog/prod...roducts_id=882
Problem is that the throttle cable would run right into the threaded-stalk on the mirror adapter (the mirror adapter is a slick c-clamp that replaces the c-clamp for the brake assembly mount). I called my dealer and the tech said they had a 796 in there, which had the stock throttle cable assembly portion rotated about 120degrees (which would be great for me!). So I guess there's some way to do this? Any ideas? I don't know how any of this shiznit works.
spindrift is offline   Reply With Quote
Old Aug 3rd, 2011, 6:09 pm   #2 (permalink)
el tardo's Avatar
to answer your question you might have to take the tube off to rotate it,not to hard,didnt look at mine.
but you do know that the large hole where the brake lever mounts to the master,its ment for a mirror to go there,you just put the mirror in place with a long bolt and a nut at the bottom. some guys here are useing aprilia mirrors
2010 black 796
dont make me badge you!!
Old Aug 3rd, 2011, 6:16 pm   #3 (permalink)
well I'm an idiot, I was wondering about those holes! I sorta forgot about them. I guess mirrors like these will just slide through NP? (then I can use their provided nut, or slide my own nuts on there...hah)
Seca 8 Composite Mirrors
That would be great since the adapters below are $50 a pop....yeah, crazy, I know...
Rob
Old Aug 4th, 2011, 8:10 am   #4 (permalink)
If you still want adapters, you can also get some from Wheeling Cycle Supply, for less. The 796 throttle cable is a close fit, but no problem.
RichardU is offline   Reply With Quote
Sat Nav mounting duke900ssd Superbikes 7 Mar 26th, 2011 11:24 am
Throttle lock and throttle resistance? axismotorrad Sport Classic 16 Feb 26th, 2009 8:37 pm
Touchy Throttle ---> Smooooth Throttle HyperToad HyperMotard 7 Jun 16th, 2008 4:02 am
Mounting it all up... TAftonomos Superbikes 0 Jan 8th, 2008 10:47 pm
GPS mounting Duc4Doc Sport Touring 3 Mar 9th, 2006 5:46 pm
