HELP - Can the stock ECU be "Flashed" with a new program? - Ducati.ms - The Ultimate Ducati Forum
Old Jul 29th, 2011, 3:05 am   #1 (permalink)
Question HELP - Can the stock ECU be "Flashed" with a new program?
I'm looking at a used 2008 Hyper (non S) that has 4500 miles and an aftermarket exhaust.
From what I read here (thank you!) I knew there needed to be an ECU change to map the ECU to the pipe.
The shop is telling me the the stock ECU has been "Flashed" with a new program to match the pipe. SOUND REASONABLE?
The bike looks great, started pretty easy from dead "cold" - in hot temps. I think it had been parked in the showroom a while - they had to hunt for the key. Idle was smooth and the throttle seemed to pick up clean from idle - but that was parked with no load on it.
Did not get to ride it, owner of the shop was away and the Employee's said only the owner can okay that...
Would a test ride be normally okay for a ready buyer?
Thanks guys!
Rango is offline   Reply With Quote
Old Jul 29th, 2011, 3:49 am   #2 (permalink)
Gilly's Avatar
Images: 17
yes the stock ecu can be flashed using products like protune, rexxer and other methods. Usually if a protune or rexxer is used, the protune or rexxer unit is kept with the bike to allow you to go back to stock or load different flashes depending on changes you make to the bike.
"Oh My!" thread link... FFS!
Old Jul 29th, 2011, 7:53 am   #3 (permalink)
what pipe(s) were on it? Was it a full system?
2008 hypermotard 1100, 2-1 Termi, Aviacompositi tail, Renthal fat bars, DP seat, Sato rear sets.
-ftp- is offline   Reply With Quote
Old Jul 29th, 2011, 1:10 pm   #4 (permalink)
dimitrinassis001's Avatar
The one shop Ive been talking to says they use the nemesis program that they use to re program the stock ECU. They use it in conjunction with the dyno.
dimitrinassis001 is offline   Reply With Quote
Old Jul 29th, 2011, 6:39 pm   #5 (permalink)
Mr Mike's Avatar
What does the startup display say ?
Mine scrolls " Redline Performance " as they did my reflash.
Says "race" with DP pipe ECU
? CUSHMAN GOLDEN EAGLE
Old Jul 30th, 2011, 1:25 am   #6 (permalink)
Based on the replies here I asked some follow up questions. Shop hasn't responded yet....
I didn't know to look at the display at startup
Great replies guys, THANK YOU
Shareware "Tuning" Program for belts CurtZX Superbikes 19 Apr 15th, 2010 8:43 am
Ducati announces "No Sleep 'Til Spring" finance program admin Ducati.ms News 3 Jan 19th, 2010 2:44 pm
"Ducati hits the AutoBlog" or, "Fanning the Flames of the redesign rumor mill" fasterdammit Monster 4 Oct 1st, 2007 8:23 pm
"race bike program...no warranty?" mad Superbikes 5 Jul 27th, 2006 5:53 pm
Stock triple clamp center "thing" - how to remove? Visolara Superbikes 12 Jun 4th, 2006 11:36 pm
