Electrical system overhaul = huge improvement in starting and low end response - Ducati.ms - The Ultimate Ducati Forum
Old Jul 24th, 2011, 11:13 pm   #1 (permalink)
protokultur's Avatar
I did all three of these this weekend:
Shorai LFX battery lfx18a1-bs12
Motolectric HiCAP wire leads replacement kit
NGK Iridium IX DCPR8EIX stock gap 0.65-0.75 mm
No way to separate each one on its own, but huge improvement in starting, post-start response, and low end response... I have the Nichols flywheel which makes cold starting a little more work than normal, you usually have to hold the throttle at 2000 rpms for around a minute before idle is smooth. Also my battery may have been a bit weak so it was going at least 5 turnovers to light up the engine. Bike is now starting on 1-2 turnovers and holds smoother idle after 15-20 seconds.
Low speed rolling stop and starting from a roll in 2nd or 3rd is now a lot smoother... Hard to quantify but I would say that smoothness sets in 500rpm lower than before. Makes a big difference here in the city.
All together this is about $300 in parts and a few hours of install time.
protokultur is offline   Reply With Quote
Old Jul 25th, 2011, 3:52 am   #2 (permalink)
I have the Motolectric HiCAP wire leads replacement kit but havent had the time to fix up yet.
Is it difficult to install??
Honda Phantom 200cc 2006 --->2007
Honda Super Four 400cc 2007--->2008
Kawasaki Concours 1400cc 2008 --->2010
Yamaha X1R 135CC - 2010 ---> 2011
Honda PCX 125CC - 2011 ---> 2011
Kymco Myroad 700I - 2011 --- >
Ducati Hypermotard 1100 EVO - 2011--->
ohayo is offline   Reply With Quote
Old Jul 25th, 2011, 3:07 pm   #3 (permalink)
You can do it in an hour or less I think. Don't get hasty with the wire clippers is my advice.
The directions are pretty sparse, here's what I got from them:
Motolectric Install Guides
Basically I just pulled the three wires off the bike and replaced them with the hicap wires one by one. The two running down the trellis front are hardest to route in there, and the hicap wire thickness is larger than stock by a few mm. This interferes with the pre-made routing path for the wires along the gas tank and beneath the front left tank fairing, but with zip ties everything fit OK.
All of my connections were very clean (new battery going in at the same time) so I didn't polish the contacts or use dielectric grease. If/when I want to do that, I'll go back and use the grease.
Old Jul 25th, 2011, 4:40 pm   #4 (permalink)
Drinky's Avatar
Images: 3
$125 for some wires ?
You can get that stuff at a DIY shop for $30 or less. It is on my to-do list, my bike also has trouble starting.
Old Jul 25th, 2011, 5:40 pm   #5 (permalink)
Abarth's Avatar
$75,-
starting upgrade for Ducati motorcycles
I'm still considering this upgrade. I don't have any issues with the bike starting, but I think that is because it is always on a tender. And I do agree it's is pricey for a few cables. But then it al should fit really well. Quality has a price.
And if you didn't notice it already, every upgrade/mod for the Hyper is twice the price.
---===[ 2008 Ducati Hypermotard 1100S (110,3 DIN RWHP) ]===---
|Modifications|
Termignoni 2 in 1 Full Exhaust System, Flowed Cylinder Heads, DP Race Cams, DP Race ECU (Reflashed for Wasp Kit), Wasp Power Up Kit, NGK Iridium Spark Plugs, Ducati Biggelaar Quiet Clutch modification, Lightweight flywheel (700 gram), DP Clutchplate, Carbon Clutchcover, DP Racing Seat, DP Oil Plug, Rizoma Grips, Rizoma Brake/Clutch Reservoirs, Rizoma Rear Blinkers, Painted Racing Stripes, DP Carbon Mudguard, HK Suspension Upgrade, Bitubo Steering Damper, STM Oil Breather, GiPro Gear Indicator, DP Clutch Slave, DesmoWorld Frame and Seat Plugs
Abarth is offline   Reply With Quote
Old Jul 25th, 2011, 6:31 pm   #6 (permalink)
Drinky's Avatar
Images: 3
Originally Posted by Abarth View Post
$75,-
But that's a general rule of thumb for any Ducati
Old Jul 25th, 2011, 6:52 pm   #7 (permalink)
HYPERR's Avatar
I installed the Motolectric cables on my 900SS along with a new starter and the bike now starts instantly. The stock Ducati cables are of such poor quality to start with, and the 15 year old cables on the 900SS had deteriorated to the point where it would get smokin' hot (and literally smoke) from the resistance. It was a ritual trying to start the bike before and it could never be trusted to go on a trip but now it's actually fun to hit the start button as it fires instantly.
As for the Hyper, yes it always cranked slow...but it always starts. It would be nice to have the fast crank and the instantaneous start that my 15 year old 900SS has but I think I'm going to leave it alone for now as it really isn't enough of a problem to "correct" right now. Maybe in the future as the POS Ducati cables deteriorate from age...
Current Rides:
2006 Kawasaki KLX250S
2004 Honda CBR600RR
2002 BMW R1150R
1996 Ducati 900SS/CR
Old Jul 25th, 2011, 7:40 pm   #8 (permalink)
Mr Mike's Avatar
Looks like a good thing to do.
I just ordered mine. $75.00
? CUSHMAN GOLDEN EAGLE
Old Jul 25th, 2011, 9:39 pm   #9 (permalink)
Eh the kit is $75 and the saved time it would have taken to make the wires the right length and heat shrunk connectors, zipties, etc. is probably more than worth the $40 difference... To me at least.
Old Jul 26th, 2011, 4:48 am   #10 (permalink)
Drinky's Avatar
Images: 3
I only looked on ebay and saw a higcap kit for 120 gbp, figured that would relate to something like $125 in the states.
Cutting the wires to the correct length and heatshrinking doesn't cost a lot of time, and I have a box with 1000 zipties for $7. But I'm more a DIY kind of guy. To each his own
748 Electrical Starting Issues ducatista01 Superbikes 7 Apr 1st, 2011 6:43 pm
Starting problems--electrical leftcoasttim Superbikes 4 Dec 6th, 2010 5:25 pm
Huge/cheap comfort improvement for 748,916,996,998 spdfrk Superbikes 6 Nov 8th, 2010 1:39 pm
ST4s electrical starting problem maxvega Sport Touring 33 Jul 29th, 2010 12:07 pm
Huge Improvement in Handling apehair Sport Touring 23 Apr 1st, 2010 11:57 pm
