Hyperplasty, full frontal pics included - Ducati.ms - The Ultimate Ducati Forum
Graves MotorsportsMotorcycle.com Classifieds!SportbikeTrackGearMotorcycle.com
Old Jul 22nd, 2011, 5:51 pm   #1 (permalink)
Confirmed Addict
v12gte's Avatar
have you had a week like this before?
...crazy work schedule, married with children, chores, honey-DOs, way too much to do...so you decide that you urgently need to spend time in a garage and start a new project?
Here is some plastic surgery I performed for no good reason, at all.
Zee MODs:
1. New Rizoma bar (wanted something more narrow to split lanes)
2. Rizoma tank reservoirs and brackets (all 3 in silver)
3. Clear plastic tubing from kurveygirl (?) on fleabay
4. CRG levers, standard length. Did not want to increase the pull effort, and prefer symmetry for brake and clutch. Black and red.
5. Rizoma grips. Just liked the design and motostrano gave me a discount incentive
6. Evoluzione 30.5 clutch slave in silver (as long as I am bleeding the whole thing, might as well help my carpal tunnel, right?)
7. I had the Aprilia mirrors, plus the original mickey mouse ones from Ducati, which caused one of the posters to say in an unrelated thread:
"Do you think you have enough mirrors?"
I took this very personally and immediately ordered aftermarket Ducati mirrors with integrated LED blinkers. I meant to get the carbon fibre ones, but they were probably fake, anyway. Also fleabay.
Lessons learned, perhaps of interest:
1. Yes, bleeding the rear brake absolutely requires taking the caliper off. And while bleeding....do not forget to put a shim between the pads. Yes, I bled mine twice. One also needs to remove the plastic cover for the brake cable in order to have room to hang the caliper on the frame with a zip tie. Do not forget to put this back on, or your chain will eat your brake line (did not have to learn this lesson)
2. I used electrical tape on the bar to help secure the 2 control pods (having pulled out the plastic tabs), but I did drill a hole in the bar for the throttle cam enclosure. I did not need to re-adjust any of the throttle settings after swapping grips, but getting the old grips off required some patience.
3. Mounting the mirrors on the clutch and brake perch via adapter was an option, but this made them stick out too much for lane splitting. I used new clamps, mounted further inboard. A little more busy, but more functional.
4. Side outflow reservoirs are the most flexible config with the rizoma brackets. The factory bracket for the reservoirs looks home-made fugly, sorry. It had to go.
5. Mirror electrical is not logical. Aftermarket mirrors with LEDs had red and black wires, while to stock wires were green and black. Black does NOT go to black, btw.
6. Blinkers in mirrors still blink a little fast, but I will either find the right resistors from a local vendor, or my hidden menu will finally switch to "LED". Or i will get used to it.
What is next? Painting the subframe red, a new and lighter shorai battery, finally the bigger tank? All of these would still be cheaper than recreational drugs or a shrink.
Hyperplasty, full frontal pics included-duc_after0.jpg   Hyperplasty, full frontal pics included-duc_after2.jpg
2008 Hyper S
2006 MV Agusta Brutale 910s
+afflicted with "Mad Car Disease", too
v12gte is offline   Reply With Quote
Old Jul 22nd, 2011, 6:51 pm   #2 (permalink)
Drinky's Avatar
Images: 3
I like your mods, especially the mirrors. However, I cannot understand why you went for the clear plastic tubing. Plastic or rubber tubing, especially with big brakes gives you a weird feeling when braking, at least, it gives me a strange feeling when braking, a bit mushy? Stock steel braided ones should be more than adequate.
Old Jul 22nd, 2011, 7:10 pm   #3 (permalink)
Confirmed Addict
v12gte's Avatar
Thanks.
So far....can't tell a difference between the stock and the clear brake lines. Here are the specs for the tubing:
KurveyGirl - Motorcycle Stuff: Dzus Fasteners, angled valve stems, Vesrah and More
2008 Hyper S
Old Jul 22nd, 2011, 7:41 pm   #4 (permalink)
joshuaz2's Avatar
the tubing is not on the pressure side of the system.
09 Honda CRF230L
joshuaz2 is online now   Reply With Quote
Old Jul 23rd, 2011, 1:44 am   #5 (permalink)
Please post a pic of the other Italian parked in the garage.
vjdup is offline   Reply With Quote
Old Jul 23rd, 2011, 2:40 am   #6 (permalink)
disgo duc's Avatar
Images: 23
wtf?hugh! doesnt make a darn difference what color the resivoir tubing is...theres no pressure there..unless you misunderstood the point..jus looks kool!
Old Jul 23rd, 2011, 8:39 am   #7 (permalink)
Am I the only one that was looking at the Maserati and Ferrari in his garage?? Damn what else do you drive??
mell0 is offline   Reply With Quote
Old Jul 23rd, 2011, 9:14 am   #8 (permalink)
Confirmed Addict
v12gte's Avatar
[QUOTE=mell0;1142160]Am I the only one that was looking at the Maserati and Ferrari in his garage?? Damn what else do you drive??[/
The love of Italian things is viral. It started with cars, mostly Alfas (gtvs, gtv6s, 164s), then the 2002 maserati coupe, and now a 1999 modena 360. The only additional toy is a 67 caddy convertible (i have both eu and american passports).
All of the cars are purchased fully depreciated and well used. They are also driven on the track and driven to work. Too many guys who spend more time polishing than driving.
2008 Hyper S
Old Jul 25th, 2011, 7:49 am   #9 (permalink)
Sweet Setup...!
What kind of BRake/CLutch fluid are you using?????
I'm digging the BLUE Fluid Color!
TicoTard is offline   Reply With Quote
Old Jul 25th, 2011, 8:23 am   #10 (permalink)
Drinky's Avatar
Images: 3
I thought the tubing went down to his calipers as well, my bad.
Mono to biposto project with Zard, pics included. Oberon Sport Classic 13 Jun 1st, 2010 4:35 am
Need pics of 05+ 749/999 termi full exhaust ZDM Superbikes 7 Nov 29th, 2009 8:20 am
Which included map for Nemesis/Full Leo Vince? shawngibson Superbikes 11 Jun 6th, 2009 1:44 am
My Custom Flyscreen, pics included, Photoshoppers help welcome Oberon Sport Classic 35 May 26th, 2009 4:30 pm
M1100s full Termi's and more...pics! kellydehn Monster 29 Apr 11th, 2009 1:50 am
