Jul 17th, 2011, 1:13 am
Official way of measuring air gap??
Im in the middle of installing my Race Tech springs. It seems that the springs Race tech created for me was about 3/4" longer than the stock, so I'm planning on cutting my spacer 3/4" to match the total length of spring and spacer. So my question is what is the correct way to measure the air gap? I found lots of conflicting information when I was searching. Do I measure the air gap with the springs and spacer out, springs out spacer in, or spring and spacer in? THANKS!
Jul 17th, 2011, 2:27 am
always with springs and spacers out. and i wouldnt cut your spacers til you try them out with the longer springs first.you can always cut them later.
2010 black 796
dont make me badge you!!
Jul 17th, 2011, 9:46 am
Thanks for the tip! I had a hard time compressing the spring just to get the cap back on, any tip on how to push the spring down while keeping the rod up to spin the cap back in? The racetech .85 springs are a lot stiffer than the wimpy stock .66.
Jul 17th, 2011, 10:28 am
So this is from another forum but maybe will help you out.
Fork Oil Change... - ADVrider
'10 hyper 796
'06 KTM 450exc(Plated)
'03 TTR-125
Jul 17th, 2011, 10:57 am
Originally Posted by Nginear
Awesome....I'll try this way today. Worse case I'll have to invest in one of these.....
Jul 17th, 2011, 12:47 pm
I would not cut the stock spacers, the RT springs should have come with spacers, I would call them to be sure, the air gap is from 100mm to 140mm, 120mm is a good place to start, springs out, forks collapsed, 7.5w fork oil. Aloha Alex
Jul 17th, 2011, 1:16 pm
before you buy that, check out the whole kit to service you forks... Fork Service Tool Kit This kit has had most special tools that we've needed so far to upgrade many forks.
The fork compressor isn't the easiest to use. It also helps to have a nice bench vice.
08 Ducati HM
03 Yamaha R6 track bike
02 Suzuki TL1000-R RIP baby
Jul 17th, 2011, 2:42 pm
When I ordered the springs, the rep at race tech told me the kit only comes with springs only and I would have to cut my stock spacers or use PVC pipes. The wrench way to install the cap back worked perfectly. Only problem is that after I put everything back in, the forks seems pretty stiff. I haven't measured the sag yet, but just looking at the static sag, the fork tube is barely moving down when I move the bike from side stand to upright . I used 120mm of air gap with spacer and springs out. 7.5w fork oil.
Jul 17th, 2011, 6:08 pm
That is why I had custom fork springs made to the stock spec, perfect "drop ins" but in a 0.85 rate, which worked out fine for my 225+lbs  , hopefully yours will work out too, Aloha Alex
Jul 17th, 2011, 11:32 pm
what spring rate did you order? and what do you weight?
2010 black 796
