The best sound is totally subjective. Listen to some bikes or if you can't, at least listen to some sound clips. What you like is all that matters.
I've grown to believe that simply bolting on an exhaust isn't a path to performance. You get performance on these bikes with a combination of intake and exhaust mods along with an appropriate fuel map followed by careful map tuning. It's a couple of percent here, a couple of percent there. Then again, that's always been the solution to funding ultimate power in any engine.
However, even if you find the exhaust that gives you the most power increase by itself, will it be the same exhaust that gives the most power with everything else optimized?
