14 tooth sprocket question 796 Hyper - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com Classifieds!
Old Jul 14th, 2011, 7:57 pm   #1 (permalink)
I removed my stock sprocket. Which had two bolts holding the clip on so that the sprocket doesnt slide on the counter shaft.
The new sprocket has nowhere to bolt too and didnt come with any c clips or anything to hold the sprocket on the counter shaft.
My question is am I missing something or is this just how it goes on?
update
Here is a picture of the sprocket on
The old sprocket with the lock washer and bolts
The box for the new sprocket
14 tooth sprocket question 796 Hyper-new-sprocket-.jpg   14 tooth sprocket question 796 Hyper-old-sprocket.jpg   14 tooth sprocket question 796 Hyper-sprocket-box.jpg
2010 Hypermotard 796 Flat Black.
vapor619 is offline   Reply With Quote
Old Jul 14th, 2011, 8:20 pm   #2 (permalink)
acesanugal's Avatar
Hey man! I just posted to your Facebook thang... Something's not right. The method of retention should be the same... Maybe there's a difference between the 696, 796 and 1100. Make sure you have the right model. Did you get it from the shop(SBMS)?
Abide.
acesanugal is offline   Reply With Quote
Old Jul 14th, 2011, 8:21 pm   #3 (permalink)
acesanugal's Avatar
I've sold my Hyper, and now I'm on a Monster 1100S. I don't really remember the sprocket configuration...
Abide.
Old Jul 14th, 2011, 8:23 pm   #4 (permalink)
i ordered it from wheeling cycle supply. its the right part. my son opened it before i came home and now im not sure if it came with a c clip or not.
Old Jul 14th, 2011, 8:42 pm   #5 (permalink)
I added pictures to my previous post
Old Jul 14th, 2011, 9:34 pm   #6 (permalink)
BKK
I have been waiting on my 14T sprocket to arrive from Italy through my Ducati dealer here in Bangkok.
They first ordered the 14T sprocket (Lightened Drilled out version) that is in the DP accessorie catelog for the 796, but it turned out to be the wrong sprocket for the 796 as was told to them from Italy.
So we are still waiting on the correct one, which will not be a drilled out one I am told.
BKK is offline   Reply With Quote
Old Jul 14th, 2011, 10:15 pm   #7 (permalink)
acesanugal's Avatar
is it just an issue of that clip being rotated so that it engages the teeth of the shaft or spline, then it's bolted in place? If that's the case, it seems like it would be secure. Anybody else?
Abide.
Old Jul 14th, 2011, 10:39 pm   #8 (permalink)
el tardo's Avatar
update
if the new sprocket doesnt have two hole to install the bolts its the wrong one,bottom line. no c clip or any thing else will hold it into place
so you got the wrong one !!!!
2010 black 796
dont make me badge you!!
Old Jul 14th, 2011, 11:46 pm   #9 (permalink)
Fin_Duc's Avatar
Yes, you sure got a wrong sprocket. It must have the two tapped holes for the locking screws.
JTF740.14 fits, for sure.
2010 Dark HM796 w. SC-Project slipon, LV cat elim. and PCV = FUN!!!
Originally Posted by 1badduck View Post
My hyper brings out the hooligan in my hooligan.
Fin_Duc is offline   Reply With Quote
Old Jul 15th, 2011, 12:01 am   #10 (permalink)
Well i guess i will have to get the right sprocket.
14 tooth sprocket on the 796? Seven9Six HyperMotard 16 Jul 2nd, 2011 5:02 pm
WTT, 42 tooth SS sprocket VTGPDUC Parts and Accessories 1 Feb 23rd, 2011 7:06 am
39 to 42 tooth sprocket whitelightning99 Sport Touring 10 Feb 25th, 2010 3:08 pm
14 tooth sprocket Dockstrada Sport Classic 16 Dec 28th, 2007 6:36 pm
43 tooth sprocket dose not fit ??? Help demoni Supersport 20 Jul 30th, 2007 2:23 am
