Ohlins/Ducabike damper combo? - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com Classifieds!
Old Jul 14th, 2011, 4:03 pm   #1 (permalink)
I was going to pick up the Ducabike damper mount kit but don't know what size Ohlins damper to get (63-120mm). They say use the Ohlins suggested size but can't find that info now that I need it. I got a nice wobble today at 95 that convinced me I may need a damper since my sag has been set and (I think) my weight is ok for the stock springs on the street.
craighjr is offline   Reply With Quote
Old Jul 14th, 2011, 6:54 pm   #2 (permalink)
Hazzbin's Avatar
Yeah, I wrote the ducabike guy twice asking about which Ohlins damper and he insisted that I should use the same one that comes stock on a Hyper. I bought a GPR and love it.
Hazzbin is offline   Reply With Quote
Old Jul 15th, 2011, 12:31 am   #3 (permalink)
disgo duc's Avatar
Images: 23
check out hyperpro if u want a topside dampner better adjustability and more reasonably priced.
Ohlins/Ducabike damper combo?-hyper-garage-003.jpg
Old Jul 15th, 2011, 10:11 am   #4 (permalink)
I like the price...more reasonable than other brands.
Which type do you have...the Active or non-Active type?
TicoTard is offline   Reply With Quote
Old Jul 15th, 2011, 12:56 pm   #5 (permalink)
I called Motowheels to order the Ducabike clamps (141) and ohlins 68mm (299) to find out that there are fitment issues with the set up. So at 440 I think that it was the most reasonably priced option but not worth the hassle if it doesn't fit well. I think I may start looking for a rotary style now that I have heard of 3 different brands with fitment issues.
Old Jul 15th, 2011, 1:19 pm   #6 (permalink)
Hazzbin's Avatar
I love my GPR and I understand that they make one for the 796. It was about a 20 minute install and is easily adjustable. A gloved thumb on the adjustment wheel and you're done. I set mine low for around town and crank it up on the fly as I am going faster. GPR also has a lifetime guarantee. I think it was $450-something which is about as low as anything out there.
Old Jul 15th, 2011, 1:56 pm   #7 (permalink)
disgo duc's Avatar
Images: 23
i believe i only payed $399 for the whole kit through anntori dist. and its an active unit. once you get front suspension dialed in you find that this bike doesnt even need an dampner..once i did ohlins carts it changed all the bad characteristics of this mardooki frontend..this front end can also be solved with just spring rate and oil/valving..i just went with carts since i got em for $500 used..but i guess a dampner cant hurt.
Old Jul 16th, 2011, 11:30 am   #8 (permalink)
Another little update. Ducabike said to use the 1198 sized damper and if there are clearance issues buy their 1198 clamp kit ($99 extra) so it would then mount like a Kyle Racing Ohlins kit then.
WTB:Ohlins bracket for 1098 Ohlins damper rocka Parts and Accessories 3 May 4th, 2011 7:11 pm
WTB: 848 Kyle USA Damper Kit with Ohlins damper Red-line Parts and Accessories 0 Feb 11th, 2010 9:42 pm
GPR style Damper v. Standard Ohlins damper JDuc Superbikes 0 Aug 2nd, 2009 9:48 pm
Wasp Steering Damper Kit and Ohlins Damper vivaleduc Sport Classic 6 Sep 22nd, 2008 7:13 pm
