Quick double check with you folks that changed your Shock or Ride Height Adjuster. - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com Classifieds!
Old Jul 13th, 2011, 12:35 pm   #1 (permalink)
I'm going to the hardware store in a few hours to pick up an extra long hex socket to hold the lower shock bolt that is deep in the swingarm on the left side of the bike (you know, the bolt where people keep losing their sockets in). For anyone that has taken this off, is the left side also an 8mm hex bolt like the right side? I just want to make sure before I come home with the wrong socket. Thanks!!!
tkl999 is offline   Reply With Quote
Old Jul 13th, 2011, 6:13 pm   #2 (permalink)
el tardo's Avatar
for the 796 its 8mm allens both sides ,im guessing the 1100's are the same
i used one side socket allen and one side L wrench allen backwards.it comes off every easy.then after the bike is held in the air i tap it out with a small screw driver.
2010 black 796
dont make me badge you!!
Old Jul 14th, 2011, 6:02 am   #3 (permalink)
nickd64's Avatar
yes it is the same as right side hex. Like el tardo, I just use a standard hex key with the long side in the swing arm and a piece of tube on the short end as a lever to undo/tighten.
Nick - 2008 Hypermotard S
nickd64 is offline   Reply With Quote
Old Jul 14th, 2011, 9:49 am   #4 (permalink)
Thanks guys! Got it done last night. A little nervous in the beginning, I slowly tapped the bolt toward the left side till I got to the shock and then the dog bone came off easily. Pop the ride height adjuster in, tightened everything back up, had a beer.
Thanks again!
Old Jul 15th, 2011, 5:17 am   #5 (permalink)
nickd64's Avatar
eezzy peezzy!! Have another beer on me
FS: Ohlins du511 shock, upper link, Ride height adjuster Red-line Parts and Accessories 5 Aug 11th, 2010 10:59 am
Ducati 749R shock, rear link assembly and ride height adjuster tye1138 Parts and Accessories 1 Jan 31st, 2010 7:28 pm
Tired of Tip-Toeing!! I need a rear shock ride-height adjuster. cincykid HyperMotard 11 May 2nd, 2008 5:39 pm
Shock-Ride height adjuster relationship stryder Sport Touring 12 Feb 11th, 2006 10:53 am
Rocks around rear shock/height adjuster mount TORC Superbikes 1 Jan 29th, 2006 7:29 pm
