Turn signal dummy light stopped working? - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com Classifieds!
Old Jul 10th, 2011, 11:46 pm   #1 (permalink)
veerossi46's Avatar
I installed LED's in the front and it worked, but flash rate was fast. Installed rear LED tail light with integrated turn signals (they work fine) and flash rate went back to normal. After installing the rear tail w/ integrated turn signals, the dummy light on my dash stopped working. Now, I might be a dummy riding around with a turn signal on- since I have no dummy light. So now, Anyone else heard of this?
veerossi46 is offline   Reply With Quote
Old Jul 11th, 2011, 9:41 am   #2 (permalink)
It's easy enough to leave 'em on even when you do have a dash light. They'll be calling you "grandpa" after watching you drive around for hours with your turn signals on...
redscout is offline   Reply With Quote
Old Jul 11th, 2011, 5:39 pm   #3 (permalink)
Quick as a lickety split
hooptygoo's Avatar
Happened when I went LED front and back as well. Switching from LAMP to LED in the dash didn't help either. My guess is that the current draw is slightly different from stock and it's making the computer freak out.
What I can't figure out is why, with all the other electro-dodads these bikes have nowadays, we still don't have self cancelling signals.
Jon
05 Sportster 1200 - Sold
82 GPz 750 - Sold
71 CL 175 Scrambler - Sold
09 Hyper 1100S "BIGTARD" - Sold
02 Monster 620 "Piccolo Mostro"
hooptygoo is online now   Reply With Quote
Old Jul 11th, 2011, 7:45 pm   #4 (permalink)
Mr Mike's Avatar
Blinker unit monitors the current draw and if a lite is bad the current is lower than normal and causes quick flashing to let you know theres trouble
Original front winkers are LED and normally can be replace with other LEDS
The rear stockers are Bulbs and when you change to LED you need load resistors. I made mine with 10 ohm 10W ceramic resistors
? CUSHMAN GOLDEN EAGLE
Old Jul 11th, 2011, 8:14 pm   #5 (permalink)
hooptygoo's Avatar
Good info. How did you wire them in?
Jon
82 GPz 750 - Sold
Old Jul 12th, 2011, 4:48 am   #6 (permalink)
veerossi46's Avatar
Yes, good info.Please let us know how they are wired in.
Old Jul 13th, 2011, 4:01 pm   #7 (permalink)
Mr Mike's Avatar
I soldered wire leads to the resistor ends,Heat shrinked the res and wire, and connected one in parallel with each rear blinker.(total of 2)
Make sure the res are not touching any plastic or other wires as they can get a little warm.
turn signal & brake light combo dpa360 Sport Classic 0 Aug 31st, 2009 1:22 pm
Turn Signal Warning Light Problem duncanmiller HyperMotard 6 Apr 5th, 2009 5:11 pm
turn signal indicator light question goyaohboyajr Supersport 6 Mar 31st, 2008 8:43 am
tail light/turn signal mod wiring? jamesmorgan Superbikes 5 Sep 10th, 2006 4:10 pm
