Hello all, coming from sportbikes I find the hypermotard throttle turn much to twist my wrist without regriping to go to full throttle. I've written many how to threads on thumertalk and r1 r6 forums but didn't see any detailed instructions on this forum, many have mentioned the mod, but didn't have detailed pics.... So I thought when I did the mod, I would take pics and give you the step by step. (BTW, Total time to install mod takes about 10 min)
This mod reduces the amount you have to turn your wrist to go full throttle, once you try this mod you wonder why every throttle isn't setup this way.
(PLEASE NOTE: do this mod at your own risk.....)
1. I purchased the R1 throttle tube mentioned on this forum..... Installed it and did not find any advantage....
2. Returned that throttle tube and purchased the R6 (2006 model) throttle tube. (yamaha Part number 2CO-26240-00)
3. Take off right hand guard, outside only.
4. Take the two screws that hold the throttle tube on off.
5. Take the throttle tube off.
6. Here is a photo with the stock tube dimensions. (37.1mm)
7. Here is the 2006 R6 throttle tube (41mm)
8. Ok, now
you can't install the r6 throttle tube without
grinding the two tabs of both sides of the housing.
9. Here is a pic of one side with the two tabs in place.
10. Get a dremel with a large cutoff wheel (2" dia.) and slowly grind the inside tabs off of
Here is a pic with the tabs ground off.
11. Clean off all shavings with carb cleaner, etc.
12. Put throttle tube in housings WITHOUT cables to test if the throttle doesn't bind, if it binds of has a bur, take it back off and grind more.
13. Once you have ensured there is no burs and the throttle tube spins without any issue, you can install the cables and reassemble throttle tube on bike.
14. You will notice the throttle is a little tight, you will need to loosen the adjustments near the fuel injection.
Here is a pic of the adjustments, make sure to loosen enough where there is slight play in the cables, SLIGHT play. The cables will bind if you don't give the cables more slack.
15. Once you adjust cables with slack, make sure the throttle snaps back in place without binding.... Enjoy the quick turn.
16. Here is a pic with the before and after twist measurements. You can see by the marks full throttle is now about 3/8" less twist, this doesn't seem like much, but it's the amount you had to readjust your wrist to get full throttle before.
17. Now is a good time to change grips.
18. Get out and enjoy the throttle, you'll swear the bike is faster now!!! haha
19. Please let me know what you think by posting results. Enjoy!!!!
