Zeta Armor handguards fitment and spacing - Ducati.ms - The Ultimate Ducati Forum
Old Jul 5th, 2011, 1:25 pm   #1 (permalink)
Ben710's Avatar
Hey all,
I fitted my Zeta Armor handguards which I had left over from my Husky. Surprisingly they donīt quite clear the master cylinders on both sides when aligned straight with them. Also I used to have them mounted on a Magura SX 28.6mm bar, now the inner mounting clamps donīt fit the Ducati bar. I measured the Ducati bar and itīs between 25 and 26mm where the clamps sit. I know thereīs another clamp kit available from Zeta, but those are for 22mm bars.
What to do?
freezer, donīt you run Zeta bars on your Hyper?
Old Jul 5th, 2011, 1:40 pm   #2 (permalink)
foxracing's Avatar
Zeta makes an extension style clamp.
Last item on this page - ZETA RACING -
They have it in 2 sizes, the smaller stock HM handlebar size and the oversize bars (i.e. your Maguras) commonly used on dirtbikes.
Hope that helps!
foxracing is offline   Reply With Quote
Old Jul 5th, 2011, 2:43 pm   #3 (permalink)
Ben710's Avatar
Hi foxracing, thanks for the reply!
That would leave the retaining bolt which goes into the side of the bar a little bent. Not the cleanest of options, no?
Just to clarify, I donīt run a Magura bar, I have the stock Hypermotard bar. Does the 22mm clamp fit?
Old Jul 5th, 2011, 8:39 pm   #4 (permalink)
foxracing's Avatar
What we did was put the alu handguard bar in a vice and bend it so it "opens" up slightly wider.
Yup the stock HM bar is 7/8" diameter.
Old Jul 5th, 2011, 10:36 pm   #5 (permalink)
freezer16801's Avatar
he beat me to it. I also had to bend the end of the guard so it would fit a bit more straight
08 Ducati HM
03 Yamaha R6 track bike
02 Suzuki TL1000-R RIP baby
Old Jul 5th, 2011, 11:56 pm   #6 (permalink)
Barkertodd's Avatar
Ditto, with the correct extension bar, I just had to bend the handgaurd to line it up just right
-Todd
'09 Monster 1100
Barkertodd is offline   Reply With Quote
Old Jul 6th, 2011, 12:35 am   #7 (permalink)
08hyper's Avatar
Originally Posted by 08hyper
OK, I did have some install issues, the aluminum handguard bar did not fit the handlebars well, the bar is designed to fit the "short" front clamp for dirt bikes, but since we have the masters on both levers we have to run the optional longer front bar clamps, there lies the problem, the angle of the handguard bar is all wrong for a clean install, putting to much stress on the bar end mount with a ugly angle, so what did I do? I found a tree in my front yard put the handguard bar in the crotch of a thick tree branch and bent it! just like a real Redneck! I "opened" it up so the longer front clamp will now fit. I knew bending it wasn't going to be a problem because the handguard bar is made from semi soft "malleable aluminum" and now the handguard bar fits well on the handlebar, like it should.
I also had to remove & reinstall my Fabbri windshield to install the front bar clamps, and just like (typhon) said, I had to put tape under the switchgear to help it tighten on the handlebar, the LED lights went in fine with NO filing, and are only half as bright as stock as they are small, and because of my Slick50 rear LEDs my turn signals now blink too fast. But in the end, after the 2 1/2 Hr pain in the butt ordeal, it turned out nice & I like it. Aloha Alex
PS: a side benefit of the bar conversion is that because of being able to move my controls around, (no locating tits) I can get my conventional mirrors out farther and I can see behind me better than ever before!
Old post of mine.... Aloha Alex
Old Jul 6th, 2011, 11:51 am   #8 (permalink)
Ben710's Avatar
Thanks all for the advice.
Are there any equally affordable handguards that fit straight onto the HYM handlebar?
Old Jul 23rd, 2011, 3:14 pm   #9 (permalink)
Ben710's Avatar
I went and ordered the extension kit with 22mm clamps, and guess what, they donīt fit...
So neither the 28.6 clamps nor the 22mm clamps fit the stock 08 handle bars. Fucking Ducati...
I dug out a Pro Taper handlebar from my basement. Itīs a bit narrower than the HYM handlebar, but the ZETAs fit.
This shit can be so annoying. Why does everything have to be genuine Ducati? Argh...
Old Jul 26th, 2011, 5:05 pm   #10 (permalink)
Originally Posted by Ben710 View Post
Hey all,
What to do?
Do you have bar end weights on your bars? I had a 2008 Hypermotard all I did was go to the longer "posts" to clear the master cylinders. The 796 does have 7/8th bars,but, not the 1100.
Fg
creamcheese is offline   Reply With Quote
bolts for peg spacing mod usefulidiot StreetFighter 1 Jul 17th, 2010 10:35 am
996 valve spacing? Reno Superbikes 3 Apr 22nd, 2010 3:28 am
Zeta turnsignals marc.danziger HyperMotard 3 Nov 14th, 2009 10:45 am
Caliper Spacing xplodee Sport Classic 5 Nov 20th, 2007 2:05 pm
