adjusted low idle air screws and synched the throttle bodies ... - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com Classifieds!Motorcycle.comGraves Motorsports
Motorcycle.com
Old Jul 1st, 2011, 9:21 pm   #1 (permalink)
johnchypermotard's Avatar
wow ... just adjusted the low speed idle air screws and synched the throttle bodies on the hypertard ... HUGE difference in right off idle throttle response.
Old Jul 1st, 2011, 11:35 pm   #2 (permalink)
i did this today too! no more stalling and looking like an idiot every time i pull the clutch in
DosHypers is offline   Reply With Quote
Old Jul 2nd, 2011, 1:34 am   #3 (permalink)
Eat, sleep, play!
dukepilot's Avatar
Images: 8
About time, what took you so long?
-2008 Hypermotard S
-2005 Buell XB9SX
-2006 Husqvarna SM610
-2004 Husqvarna SM450R
-2004 Husqvarna TE250
-2004 Husqvarna CR125
-2005 CRF170R
Old Jul 2nd, 2011, 3:27 am   #4 (permalink)
i'm a spaz
Old Jul 2nd, 2011, 11:10 am   #5 (permalink)
What did you sync your throttle bodies with? I have a Morgan Carb Tune that I was going to use on it. I've been meaning to do this since I installed my Fatduc.
tkl999 is offline   Reply With Quote
Old Jul 2nd, 2011, 12:00 pm   #6 (permalink)
i rode over to nichols sport bikes service in milpitas, and did the work there. josh did the air/fuel tweaking on the low speed idle adjust, using their dyno sniffer and the dyno-tune software. ultra accurate.
for the throttle body synch, josh used a gauge set that i have not seen before. no mercury, just hoses that went into the gauges and were adjusted by knobs.
the net-net: the low speed idle air adjustment was off by a little on the horizontal cylinder throttle body, and pretty much spot on for the vertical cylinder.
the throttle bodies were out of synch by quite a bit, and did require some tweaking.
suggest that as you are in the bay area, give nichols a call and have them do these adjustments for you.
ciao,
johnc
Old Jul 2nd, 2011, 5:21 pm   #7 (permalink)
So how can someone do this by themselves?
I don't have a shop to take my bike to nor do I have anybody that would know how to do it?
'02 1450cc Sportster
'10 BMW F800R
'11 Hyper EVO SP
canicoll is offline   Reply With Quote
Old Jul 2nd, 2011, 5:36 pm   #8 (permalink)
Hazzbin's Avatar
I was in the local dealer this morning getting my TPS reset and asked if that was something they could do. I was told "it won't help, the ECU does everything". Based on that I'm more sure than ever that I'll do my own valves and belts.
Hazzbin is offline   Reply With Quote
Old Jul 2nd, 2011, 7:45 pm   #9 (permalink)
Gilly's Avatar
Images: 17
Depending on the year of bike, it is true. MM ecu's need the tps setting done.
"Oh My!" thread link... FFS!
Old Jul 2nd, 2011, 8:33 pm   #10 (permalink)
Mr Mike's Avatar
Sounds like vacuum guages with damper valves
Cheap enough to come by
? CUSHMAN GOLDEN EAGLE
749/999 Throttle bodies daved Superbikes 10 Nov 9th, 2010 5:05 am
749/999 throttle bodies TAftonomos Parts and Accessories 0 Jul 20th, 2010 8:36 am
Throttle Bodies EIGHTfortyEIGHT Sport Classic 1 Apr 12th, 2010 3:28 pm
New throttle bodies adroc StreetFighter 6 Dec 6th, 2009 4:29 pm
Throttle Bodies bleett Superbikes 1 Apr 11th, 2006 10:12 am
