rear ride-height adjuster ... - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com Classifieds!Motorcycle.comGraves Motorsports
Motorcycle.com
Old Jun 30th, 2011, 7:07 pm   #1 (permalink)
johnchypermotard's Avatar
just raised the ride-height adjuster so the rear came up .250" from stock (i added an adjustable ride-height rod from an S model, to my base model a few weeks ago).
wow!!! even with this relatively small height adjustement, the hypertard tracks molto better, turns in faster/with more control, and exhibits zero twitchy-ness that i was sort of expecting (disclaimer: i am running an ohlins rod style damper).
next week i will raise the rear another .250" to see if this improves the ride even more, or starts to adversely effect handling.
btw, i know alex has advised to raise the rear up as far as it will go ... but i am a "little" lighter than alex , so don't want to adjust the rear too much in one session.
ciao,
johnc
Old Jun 30th, 2011, 8:04 pm   #2 (permalink)
08hyper's Avatar
LOL!! told you, crank it to the "MAX" you'll love it, and if does get too quick for you, you can drop the forks down in the triples to slow things down again, and guess what this will get you? MORE GROUND CLEARANCE!! your welcome....Aloha Alex
Old Jun 30th, 2011, 8:09 pm   #3 (permalink)
el tardo's Avatar
dont forget to not max out past this point
2010 black 796
dont make me badge you!!
Old Jun 30th, 2011, 8:15 pm   #4 (permalink)
08hyper's Avatar
That is correct, 5 threads showing, is "MAX" I'm at 7 per side, but then I live on the edge....... Aloha Alex
PS: I am in no way endorsing to go past the 5 thread mark, don't be stoopid like me.
Old Jun 30th, 2011, 8:20 pm   #5 (permalink)
i bet you have ductape holding the threads in, right alex?
ok, i will max out the ride height to 5 threads showing, and drop the fork tubes in the triple clamps if it gets too twitchy for my pussy self.
Old Jun 30th, 2011, 8:24 pm   #6 (permalink)
08hyper's Avatar
Don't forget to set you sag....it may change. Aloha Alex
Old Jun 30th, 2011, 8:54 pm   #7 (permalink)
el tardo's Avatar
good point as mine did
2010 black 796
749 rear ride height adjuster bmxer4liffe Superbikes 10 Jun 3rd, 2011 12:01 pm
ST3 Ride Height Adjuster wyst3 Sport Touring 15 Jul 12th, 2010 6:01 am
Ducati 749R shock, rear link assembly and ride height adjuster tye1138 Parts and Accessories 1 Jan 31st, 2010 7:28 pm
Tired of Tip-Toeing!! I need a rear shock ride-height adjuster. cincykid HyperMotard 11 May 2nd, 2008 5:39 pm
