Afam quick change Sprocket and chain tension help - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com Classifieds!Graves MotorsportsMotorcycle.com
Old Jun 22nd, 2011, 5:25 am   #1 (permalink)
hyperichie's Avatar
This is my 5th chainand sprocket kit I have installed and really never had a problem.
SO when the wheel rotates the chain tension will get loose then tight then loose then tight?? What would cause this?? I torqued down the all the sprocket bolts too?? Im soo pissed about this after spending $300 plus on this kit.
Can those 5 little cush drive things go bad? The hyper only has 5500miles on it!
Thanks so much
08 Ducati Hyper 1100
06 Honda CRF-88cc SM
07 Husky SMR 510 (sold)
05 Suzuki GSXR 1000 (sold)
06 Suzuki DRZ 400sm (sold)
04 Suzuki GSXR 750 (sold)
01 Yamaha R6 CLE (sold)
hyperichie is offline   Reply With Quote
Old Jun 22nd, 2011, 9:31 am   #2 (permalink)
08hyper's Avatar
That's funny, I seem to a little of the same problem, just noticed it last weekend, mine's not real bad thou, but I can see the sprocket "move" front to back when I look at the sprocket teeth tip in relation to the fixed swingarm. I would try to move the chain to a different spot on the rear sprocket & see if it gets any better. Aloha Alex
Old Jun 22nd, 2011, 9:34 am   #3 (permalink)
hyperichie's Avatar
yea mine isnt that bad but def not good. I wonder if I loosen all the sprocket bolts and spin the wheel. Then re torque?? This shouldnt be that off since it is a single sided swinger!
Old Jun 22nd, 2011, 9:48 am   #4 (permalink)
08hyper's Avatar
Couldn't hurt, I'd give that a shot, just retorque in a "star" pattern. Let us know how it works out. Aloha Alex
Old Jun 23rd, 2011, 2:51 pm   #5 (permalink)
hyperichie's Avatar
Ok well I tried everything and it still goes from a loose good feeling chain to then a pretty tight chain when just turning the wheel. Is this normal at all?
Thanks
Old Jun 23rd, 2011, 3:02 pm   #6 (permalink)
hyperichie's Avatar
I made sure the sprocket was triple checked with the proper torque settings and it's not bent. I asked the Sprocket Center and they said it could be a worn cush drive or etc.. Any help or ideas would be great!
Thanks
Richie
Old Jun 23rd, 2011, 10:47 pm   #7 (permalink)
08hyper's Avatar
Do you see the sprocket move front to back when you spin the rear wheel?
If not, its possible that the chain is bad. Aloha Alex
Old Jun 23rd, 2011, 11:35 pm   #8 (permalink)
Decreasing Dave's Avatar
Images: 14
Afam is chinese for "egg"
Dave
My DOC Welcome Kit
Dave Yeski
CCS Southwest Expert #99
(apparently retired....)
2008 Hypermotard S Black!!!!
2006 Yamaha YZ450F Supermoto
Old Jun 25th, 2011, 3:08 pm   #9 (permalink)
hyperichie's Avatar
OH NO Dave please dont tell me that!! I got the 520 conversion and DID ERV3 chain. I doubt the chain is bent ITS BRAND NEW...
I did jerry rig a piece of metal to touch the sprocket and then I spun the wheel and the sprocket never moved the metal away like it would if it had a slight bend. I want to ride it so bad what else do you guys think it could be? This is so frustrating. This is not my first chain install and I thought with a single sided swing arm it would be easy!
08 Hyper what do you mean seeing the sprocket move back and forth? You mean side to side? I can move the sprocket a lil from side to side by hand and I think i see the sprocket move just a tad when I spin the wheel..
Old Jun 25th, 2011, 8:03 pm   #10 (permalink)
08hyper's Avatar
I mean front to back, not side to side, when I look at the sprocket teeth tip, and look at the swingarm where the sprocket come closest to, I can see where my sprocket slightly moves front to back, causing the chain to get tight & loose. (slightly) I've got 6000mi+ now so its a little late for me to do anything about it. I'll take apart everything when I replace the chain at the 10,000 mile mark, and see what I find. Aloha Alex
WTB AFAM Ducati 525 Alloy Rear Quick Change Sprocket 39T Anarchy919 Parts and Accessories 0 Mar 20th, 2011 4:58 pm
Wanted: Afam quick change sprocket 41 steel for 848 PhilDucati Parts and Accessories 0 Mar 3rd, 2011 2:43 pm
wtb New Afam 520 quick change rear sprocket 39 neuroduc Parts and Accessories 7 Sep 20th, 2010 10:07 pm
WTT... AFAM quick change sprocket and chain kit IKAIKA808 Parts and Accessories 1 Jun 24th, 2010 1:24 pm
AFAM quick change sprocket for 748 748vinny Superbikes 5 Jun 11th, 2008 7:08 am
