lowering links - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com Classifieds!Motorcycle.comGraves Motorsports
Graves Motorsports
Old Jun 12th, 2011, 4:46 pm   #1 (permalink)
lowering links
What lowering links are available for an 08? And how much shorter will the seating position be? Thanks! Dianne
east tennessee dianne is offline   Reply With Quote
Old Jun 12th, 2011, 9:19 pm   #2 (permalink)
NikMusolino's Avatar
Search "Ride Height Ducati Hypermotard" on eBay. Any of those will fit Your 08 base model Hyper. Installing and lowering may make the bike considerably lower for static comfort, but be advised, the "stinkbug" stance of the Hypermotard places the necessary weight on the front wheel, providing the nimble attitude of the motard. Actual riding or sitting "static" at a stop light... wherein You choose Your comfort is up to You. Find the compromise that suits You & get Your suspension set up professionally as soon as You get the ride height adjuster installed...
'09 HYM1100S Nero
Old Jun 12th, 2011, 10:28 pm   #3 (permalink)
el tardo's Avatar
the bad part about the above comment is the ride height adjuster in meant to raise the bike and doesn't really go lower. you will need to have one cut (take about a inch out)and re welded so you can have more adjustability. i have a stock non adjustable one you can have for free,as i have the adjustable one needed to raise the bike so it corners better.
you can also have the seat shaved to take out about a inch to two inch's but it will be like sitting on a board.
best of luck and feel free to ask any questions
2010 black 796
dont make me badge you!!
Old Jun 13th, 2011, 6:02 am   #4 (permalink)
I already have a Sargent low seat shaved to the plastic. It's okay for the street, but I tiptoe in gravel and uneven pavement.
Old Jun 13th, 2011, 10:09 pm   #5 (permalink)
how tall are you? i am 5-6" and i tiptoe too, most of the time i flat foot one and other foot on peg.
nikkihyperr is offline   Reply With Quote
Old Jun 14th, 2011, 8:03 pm   #6 (permalink)
5'5". i would like to have the seat another inch lower. However, after reading there are comprises to be made. Still thinking....
Old Jun 15th, 2011, 1:21 am   #7 (permalink)
Dianne, I do believe this is what You need.
SATO RACING | Ducati Multistrada / Hypermotard Suspension Link Rod
'09 HYM1100S Nero
Old Jun 15th, 2011, 1:24 am   #8 (permalink)
el tardo's Avatar
great find. she will still need the adjustable eye bolts to make it work
2010 black 796
Old Jun 15th, 2011, 10:53 am   #9 (permalink)
Thanks for the help! Adjustable eye bolts too- okay. I have the 7500 check up due in about 600 miles. I was going to have the shop install/ help with the suspension once it's lowered. Thanks again, Dianne. All advice is appreciated. : )
Old Jun 15th, 2011, 2:26 pm   #10 (permalink)
yota's Avatar
I used the S model adjustable shock link to lower my 08 standard model about 3 years ago. just raised the forks in the triple clamps to keep the bike geomentry the same. I was tip toes every time I came to a stop and it bugged me. I am thinking about putting it all back to stock to compare the ride with the way it's been lowered.
the biggest issue I found in lowering was that the kickstand keeps the bike more upright and you have to make sure the front wheel is turned to the left when parking or it can be tippy.
see forks in pics.
yota is offline   Reply With Quote
WTB GT1000 center stand, Gauge lowering links, Rossi hugger erichan8757 Parts and Accessories 0 Jun 20th, 2010 4:38 pm
How Many Chain Links for ST3? jgalvin Sport Touring 5 Jun 11th, 2009 9:15 am
How many links?? Fivespeed Supersport 1 Mar 29th, 2008 7:36 pm
# of links in a 15t/39t set up fasterdammit Monster 4 May 9th, 2007 8:44 am
