Can't make it work! VDST - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGear
Old Jun 6th, 2011, 7:43 pm   #1 (permalink)
I have issues configuring my VDST:
1- When I try to configure the USB connection controller and com I can't have it on the com3 only com9? Is it a big problem, I don't know? When I look in the port I don't see any others but when I try to change the com9 to com3 it says that com3 is already in use?
2- When I connected first the VDST to the bike I notice that on the 3 pin connector of:
-the VDST only left & right were used and center was empty(no wire)
-the bike the center & left were used and right is empty(no wire)
So my logic tell me that something is wrong but maybe...
3- When I connect to the bike I can't establish connection but anyways I think that I need to solve 1 & 2 before...
Thanks
joeracing1 is offline   Reply With Quote
Old Jun 6th, 2011, 10:08 pm   #2 (permalink)
What bike and what vdst code?
craighjr is offline   Reply With Quote
Old Jun 6th, 2011, 11:37 pm   #3 (permalink)
elliott5's Avatar
And what operating system?
XP. Vista, Window 7?
2008 Hyper S
2007 FZ1N
2007 ZX6R (Track)
2004 CBR1000RR
1998 TRX 850
elliott5 is offline   Reply With Quote
Old Jun 7th, 2011, 1:14 am   #4 (permalink)
Banned
Images: 19
Your not holding your tongue in the correct position!
Or you have the wrong shoes on!
Sorry, just dick'n around.
Hope you figure it out mate, there's a wealth of experts here at .ms to help. I'm not one of them.
Tard is offline   Reply With Quote
Old Jun 7th, 2011, 2:23 am   #5 (permalink)
Gilly's Avatar
Images: 17
There is a FAQ on Technoresearches site on the USB/Serial port setup. You should make sure that the settings in the computer are the correct ones for the USB/Serial adapter. Hope this helps....
PART ONE
Do I need specific settings for these adapters?
A: Part 1: For the Keyspan, YES: Go to: All programs then Keyspan USB Serial Adapter.
Run the Keyspan Serial Assistant.
Under Properties set endpoints to: High Performance (Bulk);
Transmit Completion Timing Advance to: Faster; and
Receive FIFO Buffer Size to: 63.
PART TWO (just explains how to tell which port is being used by the USB/Serial Adapter)
If1. If Microsoft XP Operating System is in use, use the following steps:
->Start Menu
-> ControlPanel
A. Classic View in use:
-> System
->Hardware Tab
-> Device Manager
-> Ports (COM & LPT)
*Note Communications Port number that is present or in use
B. Category View in use:
-> Printers and Other Hardware
->Upper Left System Option
-> Hardware Tab
-> Device Manager
C. Classic View in use:
-> Performance & Maintenance
-> System
->Hardware Tab
-> Device Manager
2. If Microsoft Windows 95,98, ME Operating Systems are in use, use the following steps:
->Start Menu
-> Settings
-> Control Panel
-> System
-> Device Manager Tab
"Oh My!" thread link... FFS!
Old Jun 8th, 2011, 9:16 pm   #6 (permalink)
Finally figured it out, the problem was that I had blue shoes on, just changed for black ones and it was fixed...:-)
I played with the port setting in the VDST software and got it to work.
Thanks for the help.
Old Jun 8th, 2011, 9:31 pm   #7 (permalink)
Gilly's Avatar
Images: 17
If you ever see on the launch where it cycles thru the ports, it is having an issue with communicating to the ecu. Most times restart the software, worse case is reboot the computer. Your settings should stick, but it doesnt hurt to paste that shit into notepad for just in case.
Old Jun 9th, 2011, 1:57 pm   #8 (permalink)
Decreasing Dave's Avatar
Images: 14
I had the same problem when I rented one from a forum member.
Sorry I didn't get to this post sooner....
Dave
My DOC Welcome Kit
Dave Yeski
CCS Southwest Expert #99
(apparently retired....)
2008 Hypermotard S Black!!!!
2006 Yamaha YZ450F Supermoto
How to properly make brakes work ! rapter Superbikes 6 Jan 31st, 2008 11:42 am
How to make the 1188 worth 32.5K and not make desmosedici owners mad spalding12 Superbikes 47 Oct 3rd, 2007 10:18 pm
how do you make Marchesini wheels work? martys Sport Classic 9 Oct 1st, 2007 6:08 am
