796 must - Ducati.ms - The Ultimate Ducati Forum
Graves Motorsports
Old May 28th, 2011, 6:39 pm   #1 (permalink)
el tardo's Avatar
796 must
i just changed out the stock shock for a sachs shock off a 1100 hyper and man does it make a difference.
i had the 796 dialed in pretty good but it still wasn't perfect,now with the new shock no more squat in the rear. on the stock 796 shock,to set sag i had the preload collars almost all the way at the bottom to get to 35mm of race sag,the new 1100 shock its at the top to get the same sag number,so it obviously has a stiffer spring rate in it.and also no more wallow in high speed turns.
i did have to move the O2 senor to a different spot but that was easy.got a
O2 bung of ebay for 3 bucks and had a muffler shop weld it in for 20 bucks.cant beat that!
2010 black 796
dont make me badge you!!
Old May 28th, 2011, 9:07 pm   #2 (permalink)
Decreasing Dave's Avatar
Images: 14
easy cheesy...
My DOC Welcome Kit
Dave Yeski
CCS Southwest Expert #99
(apparently retired....)
2008 Hypermotard S Black!!!!
2006 Yamaha YZ450F Supermoto
Old Jun 1st, 2011, 9:50 am   #3 (permalink)
you still have your 1100 height adj bar set at the same level or did you change it. And is the relocation of the O2 sensor something I could do with the stock catted pipe?
cpike is offline   Reply With Quote
Old Jun 1st, 2011, 5:08 pm   #4 (permalink)
el tardo's Avatar
yes still have the height adjuster at the same,when i measured it before and after it came out to be the same. and yes to the second question.
2010 black 796
