Originally Posted by ktrides2
awwww
OK now I feel bad......so here are my mods, for the Motor of Death II "PERFORMANCE & "ENGINE ONLY"
1. Opened up stock airbox top & bottom, BMC filter & aluminum top filter plate
2. Bursi Evolution race lge tube header with Leo Vince slip-ons
3. 100mm big bore Pistal HC pistons 1123cc
4. Ceramic coated piston tops & combustion chambers, slick piston skirt coating
5. Heat radiating exterior cylinder coating (black)
6. Full head porting & polishing with oversized intake valves
7. DP performance cams & cams racing ECU
8. Lightened stock flywheel
9. Lightened balanced crankshaft with Carillo super lite rods
10. Ceramic crank bearings
11. Blue printed motor to "Corsa" specs
12. Pure Power aluminum oil filter with high flow S/S cleanable screen
13. Oversized Febur aluminum oil cooler
14. DP race slipper clutch
15. Dyno jet quick shifter
16. Barnett clutch basket with S/S finger inserts & plates
17. NGK iridium spark plugs
18. Carbon side scoops to blow air on the rear cylinders
19. 30mm clutch slave
20. DP rear sets
21. Too much money
22. But now at 106hp at the rear wheel rear, helps just a "little"
Aloha Alex
