You really don't need race gas in your Hypermotard, I have high compression pistons in my Hyper and just use pump gas "super" in fact you may loose power if the octane is too high.
If you bike just started to run lean, it might just be a small air leak, check around the intake manifold, loose bolts, missing plugs, vacuum line off, etc.etc. You can even spray starter fluid around that area, if your idle goes up, "BINGO"
And "RACE" gas will run "white" at the tailpipe, and may take a few tankfuls or regular gas to "darken" the tailpipe back up especially if its running a little lean anyways. Aloha Alex
