May 20th, 2011, 8:33 pm
LV Cat Eliminator???
So I just got the eliminator and I cant get the sensor out. Any ideas? And does this need to go back in, as the LV has a cap for where it goes?!?! Tired of searching and the instructions blow...
May 20th, 2011, 9:03 pm
Yes you take the sensor off the cat and then install it into the LV cat eliminator. It was three years ago so my memory is fuzzy but I believe you loosen a nut with a wrench to pull out the sensor. I do remember the entire procedure of the removal of the cat and the installation of the eliminator to be a very smooth process with no SNAFUs whatsoever.
Current Rides:
2008 Ducati Hypermotard 1100
2006 Kawasaki KLX250S
2004 Honda CBR600RR
2002 BMW R1150R
1996 Ducati 900SS/CR
May 20th, 2011, 9:50 pm
I got it thanks. Everything went smooth except for that damn sensor. Dint know if I needed it though since LV gives you a cap for it?!?! Just made me question what I was doing.
May 20th, 2011, 11:53 pm
I have mine sitting in a box. Waiting until i reach 1000 to break in the bike before i instal it. Does it sound better?
May 21st, 2011, 1:26 am
Depending on year bike and which ECU you are running, will determine whether or not you can remove the O2 sensor.
After the cat is removed the bike will sound much better, like you put on a set of slip ons, the throttle responce will be better, and you might gain a hp or two. Aloha Alex
May 23rd, 2011, 8:08 pm
After a few rides the biggest thing I notice is the throttle, not as jerky, and yes it does sound better.
May 23rd, 2011, 10:08 pm
Hi,
I am running termi slip on the 1100 EVO. Can i fix the LV Cat eliminator together with the termis? Or i have to get leo vince slip on to match their cat eliminator?
Honda Phantom 200cc 2006 --->2007
Honda Super Four 400cc 2007--->2008
Kawasaki Concours 1400cc 2008 --->2010
Yamaha X1R 135CC - 2010 ---> 2011
Honda PCX 125CC - 2011 ---> 2011
Kymco Myroad 700I - 2011 --- >
Ducati Hypermotard 1100 EVO - 2011--->
May 23rd, 2011, 10:27 pm
You can use the LV with the Termis.
Dave
My DOC Welcome Kit
Dave Yeski
CCS Southwest Expert #99
(apparently retired....  )
2008 Hypermotard S Black!!!!
2006 Yamaha YZ450F Supermoto
Oct 24th, 2011, 6:27 pm
I'm in the process of installing my cat elim, got the sensor removed and now I am not sure if I should put it back in the LV. I've got an '08 1100, with the LV elim, LV exhaust, MWR small air filter, and I'm getting the ECU reflashed for all this. Will the reflash make it so I don't need it?
Thanks
Tyler
'08 Hypermotard
Oct 24th, 2011, 9:08 pm
Thanks
You have to put it back or else you will get one of those error codes. I have lv cat delete with the termi slipons and dp ecu. If you get the race ecu that comes with the full system then it by passes it as far as I know.
