Oil Mesh Filter - Hex size? - Ducati.ms - The Ultimate Ducati Forum
Old May 17th, 2011, 3:21 pm   #1 (permalink)
I'm about to change the oil on the Hyper and I see to clean the oil mesh filter (every other change) it looks like a 14mm hex head (allen key) size, can someone confirm this?
2008 Hypermotard 1100
2010 Triumph Tiger SE
"If you want the Rainbow, you gotta put up with the rain"
twozzie is offline   Reply With Quote
Old May 17th, 2011, 4:00 pm   #2 (permalink)
Ric
Ric's Avatar
My 09 is 14mm.
2001 Goldwing 1800
2009 Hyper 1100S
Ric is offline   Reply With Quote
Old May 17th, 2011, 7:32 pm   #3 (permalink)
HYPERR's Avatar
Yep 14mm it is for my '08 as well.
Also fits the front axle nut of a 1996 900SS as well.
Current Rides:
2008 Ducati Hypermotard 1100
2006 Kawasaki KLX250S
2004 Honda CBR600RR
2002 BMW R1150R
1996 Ducati 900SS/CR
Old May 17th, 2011, 10:07 pm   #4 (permalink)
Moderator
jwsparkes's Avatar
yup. 14mm and a bitch to crack open for the first time! Usual thread counter clockwise to remove.
If you have the outer cap (with the brass temp sensor) on the outside, that's a 21mm socket.
jwsparkes is offline   Reply With Quote
how to remove mesh filter???? leck02 Superbikes 4 Oct 14th, 2009 11:08 pm
999 Mesh filter 100beck Superbikes 3 Sep 6th, 2008 3:56 pm
Socket for mesh filter desmo_pt Superbikes 3 Jul 24th, 2008 1:06 am
mesh filter... ENGAKATS Supersport 4 Aug 17th, 2007 10:16 pm
Little oil seepage at mesh filter... grendels_arm Superbikes 10 Feb 8th, 2007 12:00 am
