Dyna bead wheel balancing - Ducati.ms - The Ultimate Ducati Forum
Old May 17th, 2011, 2:24 pm   #1 (permalink)
Question Dyna bead wheel balancing
Does anyone have any experience or recommendations using Dyna Beads for balancing the rear wheel? I've mounted new tires but I am having a hard time finding any dealers in the Cincinnati area who can properly balance our offset, single-sided rear wheel.
Thx
SP_rider is offline   Reply With Quote
Old May 17th, 2011, 2:55 pm   #2 (permalink)
johnchypermotard's Avatar
Thx
peter (dukepilot: http://www.ducati.ms/forums/19342-dukepilot.html ) has run dynabeads in his bikes for a few years now ... i bet he can provide you with some insight.
Old May 17th, 2011, 3:11 pm   #3 (permalink)
Mr Leakered
tonered's Avatar
Images: 14
I've had them for about 7,000mi or so. I was pretty anal about static balancing, and the Dynabeads were much smoother than anything I ever felt.
BTW, you can get Hyper cones for static balancers if you want to go that route:
Ducati Motorcycle Wheel Balancer
I bought my Dynabeads from JC, a forum sponsor:
JC/PAKBIKES
One note, it is cautioned to not use Dynabeads on the track because the carcass of the tire gets warm enough for the beads to embed themselves and not float around.
Mine have been perfectly smooth in some triple digit bursts.
Have a good one.
tony b
2001 ST4
tonered is online now   Reply With Quote
Old May 17th, 2011, 3:34 pm   #4 (permalink)
Thx for the input guys. I'll follow up on your leads.
Old May 17th, 2011, 4:08 pm   #5 (permalink)
minusone's Avatar
make a friigin mess in the shop ,when you change tyres.
Old May 17th, 2011, 4:27 pm   #6 (permalink)
Ric
Ric's Avatar
I never bother balancing rear tires for street or track.Once you mount the wheel with chain and sprocket on the bike,it's out of balance anyway.Dyna beads are for Semi's and Goldwing tourers.And the same folks use octane booster.
2001 Goldwing 1800
2009 Hyper 1100S
Ric is offline   Reply With Quote
Old May 17th, 2011, 5:11 pm   #7 (permalink)
Official Sponsor
JCPakBikes's Avatar
We have run Dyna Beads in our Alpina Tubeless Spoke wheels on our Sport Classics for some time now with excellent results.
No nasty weights to mar the beautiful Wheels
The tires seem to wear more evenly and the ride is smoother.
You will need 1 ounce in the front and 2 ounces in the rear
The MC kit is $20 shipped Comes with Applicator
JC/PAK Bikes DynaBeads Tire balancing Beads
Jc
jc@jcpakbikes.com
JCPAKBIKES
sportclassicspecialties.com
FLEDA LEGACY
ALPINA WHEELS USA
AELLA CASUNO
Old May 17th, 2011, 6:10 pm   #8 (permalink)
Eat, sleep, play!
dukepilot's Avatar
Images: 8
The dynabeads work (on the street, no track use). As minusone said, they can be messy when it comes time to change tires. You can vacuum most of them out and reuse them although that's a big PIA.
-2008 Hypermotard S
-2005 Buell XB9SX
-2006 Husqvarna SM610
-2004 Husqvarna SM450R
-2004 Husqvarna TE250
-2004 Husqvarna CR125
-2005 CRF170R
Old May 18th, 2011, 12:39 am   #9 (permalink)
Home of vortex tuning
CDONA's Avatar
I've had my back wheel balanced in a auto tire shop twice, static balanced once using HD steering head bearings as spacers.
Old May 18th, 2011, 12:58 am   #10 (permalink)
el tardo's Avatar
dont worry about it, no need to balance the rear. i havent yet and its fine three times at any speed. now the front is very important and you will feel vibes from it.
just my two cents
2010 black 796
dont make me badge you!!
Bead Blasting Hub Duccout Sport Classic 12 May 16th, 2010 2:27 pm
Dyna Bead Experiment Drbone641 Sport Touring 2 May 6th, 2010 8:44 am
Question concerning wheel balancing... Soulsedge Superbikes 2 Jun 3rd, 2007 11:41 pm
wheel balancing Herbivator Superbikes 3 Mar 29th, 2006 11:21 am
Balancing adapter for rear single-sided wheel duc995 Superbikes 4 Feb 9th, 2006 9:25 am
