Rizomi Engine Guards Install ????? - Ducati.ms - The Ultimate Ducati Forum
Old May 12th, 2011, 6:43 pm   #1 (permalink)
1sicmofo's Avatar
Exclamation Rizomi Engine Guards Install ?????
i just bought a set of these engine guards look well made
however the instructions are shit
any one installed these ?
Do you need to support the motor ?
Any help would be appreciated
1sicmofo is offline   Reply With Quote
Old May 12th, 2011, 10:07 pm   #2 (permalink)
Official Sponsor
motomfg's Avatar
I am not sure if you have to support the motor. But I do know the torque spec is 60Nm.
motomfg is offline   Reply With Quote
Old May 13th, 2011, 1:22 am   #3 (permalink)
vladimir's Avatar
I just took off the rubber stoppers on either end. Then placed the new engine rod end-on-end against the original engine bolt and slowly tapped it through with a rubber mallet.
I didn't need to put the engine on a stand, as it seems that the frame does support it well - the mounting bolt holes on the engine extend a bit out and into the frame so it seemed well enough supported.
Just don't rush it and gently tap the other bolt through so at least one side is supported by the new bolt and it should all be good.
vladimir is offline   Reply With Quote
Old May 14th, 2011, 5:47 am   #4 (permalink)
1sicmofo's Avatar
Originally Posted by vladimir View Post
i just took off the rubber stoppers on either end. Then placed the new engine rod end-on-end against the original engine bolt and slowly tapped it through with a rubber mallet.
thanks !!!!!!!!!!
Old May 14th, 2011, 11:00 am   #5 (permalink)
PJFZ1's Avatar
Ditto what Vlad said.. You should be able to get away without supporting it.
If loud pipes save lives, imagine what learning to ride that thing could do!
PJFZ1 is offline   Reply With Quote
Old May 15th, 2011, 10:59 am   #6 (permalink)
1sicmofo's Avatar
Originally Posted by 1sicmofo View Post
thanks !!!!!!!!!!
Finished when i got more then half way thru the bolt just fell out
torque is 63 to 70 nm which is about 55lbs.
thanks again for the help !!!!!!!!!!!!!!!!!!!
F/S Misc engine parts for Ducati 1000DS engine Ducracer16 Parts and Accessories 2 Aug 2nd, 2010 6:10 am
engine stall after Leo Vince install John Superbikes 7 Jun 21st, 2010 8:15 pm
DP termi 2-1 install PDF and DP tank bag install PDFs ... johnchypermotard HyperMotard 2 Apr 27th, 2010 7:00 pm
Leo Vince SBK install on 1098, engine light stays on jduc1098 Superbikes 3 Dec 22nd, 2009 10:47 pm
Where is the engine code located and is this number scratched out on your engine? auto3251 Superbikes 6 Oct 23rd, 2008 11:52 am
