Originally Posted by krisnet55
So I have been doing some reading and noticed a lot of guys are going up a tooth or two on the rear or -1 in the front. But I also did catch that the EVO has 41 teeth in the rear rather then 42 teeth as the previous model, both in stock form
Ive always done the front sprocket on all my sport bikes which translates to about + 2 - 2 1/2 in the rear. My concern is that I dont want to have 1st so short it will feel like a tractor trailer making 1st very very short.
So has anybody gone with a tooth or two in the rear on the EVO?
Im debating between +2 or +1 in the rear, but im afraid that +1 isn't gonna make that big of a difference but on the other hand im afraid +2 will make 1st very short.
Any experience as far as 1st with the +2 set up.
Fawking Ducatis, I would get both 42 and 43 if they wernt $150 bucks a pop!!!!!!!!!!!!!!
1 tooth on the front is approx 3 on the back, not exactly but very close.
I'm running a 15/43. 1st is fine & I can now hit redline in 6th
Both the Hyper 08/09 and the 11EVO have the same trans
Ducati put a 41 rear on the EVO because the stock motor now makes more power and can pull the gearing easier and for noise emissions.
I would install +2 on the back if you want to feel it. Aloha Alex
