Ducati 796 Mirror problems - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.comGraves MotorsportsMotorcycle.com Classifieds!SportbikeTrackGear
Graves Motorsports
Old May 7th, 2011, 5:59 pm   #1 (permalink)
So the other day i was riding and i noticed my right mirror was VERY loose... like about to fall off......but all the bolts were VERY tight. It seems like the inside plastic of the mirror itself is stripped.....Anyone have the same problem? Any quick tips....I have been just folding them in and look behind me when i ride now.
tlalumiere is offline   Reply With Quote
Old May 7th, 2011, 7:01 pm   #2 (permalink)
Got a screw loose?
Im not sure if it was quite the same problem you have but my mirrors were loose and never stayed in position no matter how tight the lock nuts were done up. Turned out the screw at the back of the nuckle joint was loose. Stuck a lil thread lock on them before tightening those suckers up and now my mirrors are rock solid at all speeds !
Foo
Fooman is offline   Reply With Quote
Old May 7th, 2011, 8:41 pm   #3 (permalink)
No i checked the single screw on the knuckle and they are extremely tight.... the plastic screw is tight also but my mirror is still floppy... like the inside is stripped.
Old May 7th, 2011, 8:52 pm   #4 (permalink)
el tardo's Avatar
you can fold the mirror in and on the back there is a Philip screw that you can check if its loose.
2010 black 796
dont make me badge you!!
Old May 7th, 2011, 9:53 pm   #5 (permalink)
My 796 (purchased Dec 18 2010) came with the wrong internal brass handle bar compression fittings .... my dealer took care of it sent the correct fittings to my door..... No Charge. The fix correctwd the looseness. I have since trashed the plastic guards and went to Zetta bars, clamp,.....and Aprillia mirrors.
H
hoveyh is offline   Reply With Quote
Old May 8th, 2011, 9:19 am   #6 (permalink)
I tried that both philips screws are tight.... Ill call the dealership about it
WTB // 2005 Ducati 999 MIRROR STAYS. nysid2007 Parts and Accessories 0 Aug 6th, 2010 4:01 am
FS:Ducati 999/749 Mirror - Right Side - Red osayek Parts and Accessories 2 May 7th, 2010 6:36 am
Ducati 696 Mirror rock! akillya Sport Classic 19 Dec 9th, 2008 11:48 am
Ducati Mirror Relocator typhon HyperMotard 8 Nov 22nd, 2008 4:20 pm
Ducati Mirror Bars sinex HyperMotard 11 Oct 30th, 2008 8:45 pm
