Customizing your stock seat - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGearMotorcycle.comMotorcycle.com Classifieds!
Graves Motorsports
Old May 3rd, 2011, 2:08 pm   #1 (permalink)
So there are lots of threads about what seat to use on the Hyper, the pros and cons of each. The stock seat was uncomfortable and the DP Comfort seat not much better (IMO), Yes I could payout for a stock custom seat like sargent but before shelling out $400 or so of my hard earned cash I wanted to try changing the stock seat, if I screw it up I can get another off fleabay for a few bucks. So here is what I did:
1) found a link to how to customize your seat
Modify Seat
2) Removed the seat from the bike and removed the cover, put the seat back on the bike sans cover, sat on the seat and had the wife mark out where my butt came. (ignore the grey tape, I used it whilst riding the bike to test the seat shape later)
3) Then using a electric kitchen knife (new from Walmart for 3 bucks !!) I started shaping the seat to get more of a "bowl" effect front to back and side to side. This is very messy. I then fine tuned the shape using a dremel with a sanding bit (wear a mask and goggles for this, it gets everywhere).Constantly sitting on the bike, marking and adjusting. Do this off the bike as the foam gets everywhere.
You can see how much foam I removed in the above pictures.
4) I then rode the bike for a while to fine tune where I should be taking foam out of. (there is plenty of foam on the stock seats so no worries about taking too much off)
5) When the seat was as a I wanted, I marked where the 2 seating bones would be (these are the ones that cause the irritation - the link above explains more on these) cut out the foam using a very sharp modellers knife (few bucks), all the way to the seat pan.
6) I sat on the bike again to make sure they holes were in the right place (man this was so comfortable as there was no foam pushing against the sitting bones). I then filled the holes using an open foam I had (bought at a local craft store for a few bucks)
7) Tried the seat again and then took the whole thing to my local upholstery place. He glued the "green" foam in place then using his professional eye and tools fine tuned the foam and the seat, then he covered the entire seat with 1/4 "foam to remove any imperfections and recovered the seat using the original vinyl. ($80 got the job done)
2008 Hypermotard 1100
2010 Triumph Tiger SE
"If you want the Rainbow, you gotta put up with the rain"
twozzie is offline   Reply With Quote
Old May 3rd, 2011, 2:12 pm   #2 (permalink)
couple more pics
Old May 5th, 2011, 6:39 am   #3 (permalink)
merovingian's Avatar
I've had a spare OEM seat sitting in the box for a year now. You've just inspired me to do something with it.
Cheers
merovingian is offline   Reply With Quote
Old May 5th, 2011, 1:47 pm   #4 (permalink)
ktrides2's Avatar
I just modified mine too. I shaved from the bottom though, to maintain the look of the seat and I inserted a rectangle of gel in sitting zone for extra comfort without all the thickness.
GirlRiders.net
2010 Ducati Hypermotard 796
2005 Suzuki GSXR 750
2003 Honda CRF 100F
ktrides2 is offline   Reply With Quote
Old May 7th, 2011, 11:06 am   #5 (permalink)
AXE
AXE's Avatar
Nice job. I think that will work well and actually appears to be in line with the Comfort Seat and Racing seat. I have the comfort seat and it works well for me. I sort of wish I would have shaved my stocker like I did on my FZ1. The only thing I don't like on the Comfort Seat is the gel insert heats up in the sun and it transfers to your arse from that point forward.
Out!
2008 Ducati Hypermotard
Old May 12th, 2012, 2:48 am   #6 (permalink)
sumondabitches's Avatar
more grippy cover?
Nice... what about a more grippy cover? anyone tried this?
HT Moto Seat Cover - 09-11 Ducati Hypermotard
sumondabitches is offline   Reply With Quote
Old May 12th, 2012, 7:36 am   #7 (permalink)
beelzebob's Avatar
How on earth would that fit over a stock seat ,with out cutting the foam, I'm curious as well .Looks good in the photo(that happens all of the time though).
I like to be able to slide my butt around for setting up hot turns , I have been searching for a seat for my needs since I got this bike and found nothing I like.
I wish someone would tell us about there Corbin you know who you are.
BTW one hell of a nice job sharing how you modded your stock seat(I take apart a lot of things but the seat never crossed my narrow mind) thanks .
ride-on
Bob
2009 Hyper 1100
Nichols Flywheel
LV cat delete & exhaust
14 tooth C/S Sprocket
PCV
Duc Shop Stacks
beelzebob is online now   Reply With Quote
Old May 12th, 2012, 6:23 pm   #8 (permalink)
ktrides2's Avatar
Why would you want a grippier seat? Don't you move off the seat in turn?
GirlRiders.net
2003 Honda CRF 100F
Old May 12th, 2012, 9:06 pm   #9 (permalink)
Pure genious!!! Great work, Im gonna try this on my sons butt numbing ktm seat!
I have a perfect stock Hyper seat, w 800 miles on it, for this if anyone has $100 plus shipping
Sorry, i had to slip that in
2008 ducati hypermotard1100 w/ s4rs monster tank and seat. Custom subframe and batterybox. K&N pods, cat eliminator w two brothers can and retuned ecu. Dual 4" headlights and buell xb flyscreen...my ongoing wrecked bike project...
Previously:1999ktm motard, 1997ktm motard, 1996ktm duke, 1989 honda rc31(hawk650gt) w/gsxrforks,cbr900shock,vfr rearwheel and rvf/rc30 bodywork(my first bike/project)
booger weldz is offline   Reply With Quote
Old May 12th, 2012, 9:09 pm   #10 (permalink)
Yes, but ive got alpinestars and dainese pants and they both are too slippery to not need some sort of improved seat material. Its fine in jeans or my g string, but the leather is too slippery!
Pressure plate/Custom seat/stock seat/master cylinders/turn signals uglyducky Parts and Accessories 5 May 5th, 2011 12:27 am
1198 Part - Passenger pegs, Stock rear seat, Stock Brake lever, Taillight blowngt Parts and Accessories 5 Dec 14th, 2010 7:41 am
Modified stock seat or DP comfort seat? Any thoughts? Hypremotard HyperMotard 12 Jun 18th, 2009 3:49 am
Hypermotard Stock Seat Trade for a Comfort Seat?? vietsomot HyperMotard 20 Sep 13th, 2008 12:42 am
customizing my 848 tweek Superbikes 26 May 15th, 2008 7:16 pm
